It is currently Wed Nov 04, 2026 4:03
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
 Post subject: New Features
PostPosted: Fri Jan 30, 2004 0:27
I've got some new features you could add:
1. Lan up/down
2. Inet up/down
3. RPM of CPU Cooler or Case Cooler
4. diskfree & disksize GB display
greetz
Ch3p4cK
PostPosted: Fri Jan 30, 2004 13:32
I don't know all the plugins but most of this stuff is supported. I know that there is a disk free/disk size support and I think you might get the cpu fan speed by using the MBM plugin. I haven't looked at the network plugin but it might support some of the features
Rudi Grobler
PostPosted: Fri Jan 30, 2004 13:34
A good place to start looking might be the plugin thread in this forum
Rudi Grobler
PostPosted: Fri Jan 30, 2004 13:37
Lan and Inet up/down isn't supported. CPU Fan Speed isn't supported, too.
Diskfree and Disksize is supported but only in MB.
But also Emule or FTP Client and Server Stats and WinTV Channel Info could be added as a feature.
PostPosted: Fri Jan 30, 2004 17:20
You can find network speeds from the NetStats plugin for 0.6 version of LCDInfo. Also all information reported by Motherboard Monitor should be available with the MBM plugin.
 Post subject: How?
PostPosted: Sun Feb 01, 2004 22:07
How do I get it ?
PostPosted: Tue Feb 03, 2004 13:21
If you go to the forum from page you can see the LCDInfo 0.6 section at bottom. Then there in the General discussion forum is a thread where you can download it. Also check the other sticky threads.
 Post subject: I found
PostPosted: Wed Feb 04, 2004 23:25
But it's very silly. I can't edit the screens. It's too complicated!
PostPosted: Sun Feb 08, 2004 13:39
So you have probably read these:
http://www.skippari.net/phpBB2/viewtopic.php?t=471
http://www.skippari.net/phpBB2/viewtopic.php?t=386
It shouldn't be that difficult to edit the screens compared to earlier versions of LCDInfo. It's true that it works slightly in a different way and there are more options. You also have more control how the things show on your screen.
If you're still having problems editing the screens start a thread in the 0.6 forum and I'll give you some example and explain what things are for.
