It is currently Fri Oct 23, 2026 10:39
 Post subject: CPU Load always 0% ??
PostPosted: Tue Mar 23, 2004 23:08
Why is CPU Load always 0% even if its 100 or 43%. LCDInfo always shows 0%
I'm using LCDInfo v0.3.2 with a ks0108 128 * 64
Using Mashine:
AMD Athlon XP 2500+
1GB TwinMos Dual Channel Ram
36 GB WD Raptor
100 GB WD
120 GB Seagate
Windows XP Professional
PostPosted: Wed Mar 24, 2004 21:42
I think you are using the cpu load info that comes from MBM. Have you enabled it in your MBM settings as it's disabled by default.
 Post subject: Thx
PostPosted: Wed Mar 24, 2004 22:13
Ah yes it works.
PostPosted: Sat Oct 23, 2004 16:33
where can i it turn on?
PostPosted: Sat Oct 23, 2004 22:55
In the CPU settings of MBM! ;)
PostPosted: Sun Oct 24, 2004 15:10
TNKS
