It is currently Mon Jul 27, 2026 11:27
 Post subject: Is this possible?
PostPosted: Sat Jan 22, 2005 4:52
Hi I just got this Idea for making a homemade LCD
I wanted to know if I could use a USB to printer Cable (adapter) to connect an 20x4 LCD to the USB port?
The adapter was taken from a HP printer which was damaged... so it has one USB conector and a 36 pin male conector from the back of the printer...
Since the adapter has a converter inside de parallel port casing I was wondering if this can be done?
Thanks!
PostPosted: Sat Jan 22, 2005 8:23
This has been suggested many times before, but never have i heard of anyone getting it to work.
PostPosted: Sun Jan 23, 2005 2:18
Actually...
What you have ther might not even be a USB to Parrallel converter, it might just provide a USB to processor link right to the Printer CPU. You would have to play with it to workout whether you can get anything out of the Centronics connector.. which personally I doubt.
Let us know how your testing goes. :)
PostPosted: Mon Jan 24, 2005 7:26
Syridian wrote:
Actually...
You are right...the adapter gives USB printer support, but does not act as a second serial nor printer port...
The chip in charge of doing the interface is an Agere Uss720, which I plan to use, maybe without plug and play circuitry of the adapter, but only the single chip.
But I don´t know much about driver programing; and I will need something like that...
The other idea is to use the agere chip to interface temperature sensors, but that´s another story...
Users browsing this forum: No registered users and 68 guests
