It is currently Fri Oct 09, 2026 8:55
PostPosted: Fri Mar 03, 2006 11:38
Could I use a CCFL inverter from maplins:
http://www.maplin.co.uk/Module.aspx?Mod ... ER&doy=3m3
for a EL backlight on my Data Vision DG-24128-06 240x128 LCD:
http://www.datavision.com.tw/english/index.html
Does the Voltage and frequency matter much? (could I get away with it?)
PostPosted: Fri Mar 03, 2006 14:49
No, CCFL (for Cold Cathode Fluorescent tubes) inverters cannot drive EL sheets. You need a mini-inverter for EL, like the kind included with the EL tape from the PC modding scene.
PostPosted: Fri Mar 03, 2006 15:03
thanks for the quick reply. that sounds about right.
CCFL inverter for CCFL and EL inverter for EL
But would I be able to mod this inverter to give the correct voltage and freq i need?
OR is there a chip I can buy from say maplins to invert the DC+12v to about 300v AC?
PostPosted: Fri Mar 03, 2006 15:29
I think those modding mini-inverters will do. You can buy mini-inverters seperately but i have no clue where in the UK.
It looks like this here
http://www.apollodisplays.com/pdf_e/inv ... ns-inv.pdf
Users browsing this forum: No registered users and 253 guests
