It is currently Thu Oct 08, 2026 7:00
PostPosted: Mon Mar 06, 2006 7:37
Hi guys,
What im after is advice on a colour graphic LCD module with a decent, easy to use controller.
What im after is the following specs:
320x240 or smaller RGB colour LCD panel WITH controller!
Everything else im not to fussed about. I am interested in upgrading my graphic display to a colour one. I just want something which has built in commands i can send. Basically the same method as a graphic MONO LCD.
Thanks in advanced.
Rob
PostPosted: Sat Mar 25, 2006 16:07
What kind interface would you like it to have ? (ok reading your post again I guess a parallel interface would work)
You want to connect it to microcontroller ?
EDIT:
Just remembered that I have some 256x64 color lcds with built in controller. Might be too small resolution for you though.
Users browsing this forum: Google [Bot] and 222 guests
