It is currently Wed Aug 19, 2026 4:51
 Post subject: kyocera KCS3224ASTT-X1
PostPosted: Fri Mar 07, 2008 19:10
Hi, I'm wondering if this LCD would be able to interface into a parallel port. I'm assuming it should, but not quite sure because of the pin out.
http://www.phys.szote.u-szeged.hu/bbalazs/bb/lcd/kcs3224astt.pdf
I understand where the data lines connect, but what's throwing me off is the S, CP1, and CP2 connections. They correspond to a V-sync and H-sync, but not sure if that would be applicable to the parallel port unless I program it that way. I believe CP2 (SHFCLK) would be the equivelant of the E pin on other compatible LCDs.
Any help would be great, thanks.
PostPosted: Sat Mar 08, 2008 15:35
That appears to be a controllerless STN color display. So you pretty much need a controller to use that. Don't have a suitable controller in mind right now either that would be available at the moment...
Users browsing this forum: No registered users and 86 guests
