It is currently Mon Nov 23, 2026 15:57
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Ok..
PostPosted: Tue Feb 14, 2006 4:07
Ok.. I´ll try these pins.
Another question: You´re linking pin VDD to pin 4 of Parallel port right? My parallel por is old 5 V. So.. I have for this specific pin to have a proper source, right? A 3,3V source. But what current does it need to supply?
Best Regards,
Henrique Vilela
rickonvb@yahoo.com.br
PostPosted: Tue Feb 14, 2006 4:55
The display propably doesn't need much current at all, but as you have a 5V parallel port you need to buffer all the signals, including VDD.
 Post subject: Ok..
PostPosted: Tue Feb 14, 2006 10:05
Ok.. so.. I don´t need to have a 3.3 Source? The display can handle a 5V VDD? Thanks.
Henrique Vilela
PostPosted: Tue Feb 14, 2006 13:03
NO, the display CAN'T handle 5V. That's why you need to buffer it. Like in the schematics at the beginning of the thread. If you just use 5V directly you'll kill the display.
 Post subject: Got it!
PostPosted: Tue Feb 14, 2006 16:18
Got it!
But what about all the other pins? Do they work on 3.3V or 5V?
Thanks once again!
Henrique Vilela
PostPosted: Tue Feb 14, 2006 18:39
Every signal/voltage is 3.3V.
 Post subject: Let me see...
PostPosted: Wed Mar 15, 2006 17:30
I couldn´t make it work yet...
I don´t know if it´s the program I´m trying...
I tryed the schem:
DISPLAY - LPT
RES - 3
VOUT - (Cap - 18 )
GND - 18
SCE - 18
DC - 2
SDIN - 1
SCK - 14
VDD - 4
What program should I use for this pins schem?
Best Regards,
Henrique
Henrique Vilela
PostPosted: Wed Mar 15, 2006 19:03
With that connection (and parallel port configured to the standard 0x378 address) this should give visible results if everything is ok.
http://oms.wmhost.com/lcd/pcd8544.zip
(Quits with esc)
PostPosted: Thu Mar 16, 2006 1:04
Zee.. here´s the measures I´m getting from the pins in relation to the GND pin (18 ) after a few seconds:
Display ; LPT ; [V]
RES ; 3 ; 1.55V
VOUT ; CAP(- Pin 18 ) ; 0.10V
SCE ; 18 ; 0V
DC ; 2 ; 1.4V
SDIN ; 1 ; -0.10V
SCK ; 14 ; -0.30V
VDD ; 4 ; 1.36V
I have no idea of what is going on with these levels...
I´m using 3.3V Zeners and 1k resistors. I also am using 0.5uF capacitors (each is .5uF).
Any ideas!? I guess my lpt bus is 3V3 and not TTL as I thought. When a pin is active "1", the voltage is + -3.88V.
Best Regards,
Henrique
Henrique Vilela
PostPosted: Thu Mar 16, 2006 1:48
Well, if you get around that 3.3V from the port pins without anything connected (and without any LPT-accessing programs running) then it should be the newer 3.3V type port and you can wire the display directly into it without resistors/zeners.
 Post subject: Well...
PostPosted: Thu Mar 16, 2006 11:21
I´m using Windows XP. Does this program work with it? I´ve been told that it´s hard to work with LPT under WinXP.
I´m still trying but I don´t think that the 3.98V I´m getting from the LPT is 3v3. Could it be?
Best Regards,
Henrique
Henrique Vilela
PostPosted: Thu Mar 16, 2006 13:28
The short testprogram I posted is made to work with WinXP.
You could try first adding a regular diode (1N4148 for example) between pin 4 and VDD to lower the voltage a bit.
PostPosted: Sat Aug 12, 2006 5:28
I have built an interface board according to the schematics posted by Kalamake, but am having serious issues getting it to work. All test programs posted on this forum fail to display anything. I am confident that I have built the board correctly, but I need some guidance getting software to work with the screen.
Thank you in advance
Users browsing this forum: Bing [Bot] and 9 guests
