It is currently Fri Nov 13, 2026 4:05
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 10, 2005 11:25
Yeah - that's not the original clock from the package - i modified it a bit... ;)
PostPosted: Tue May 10, 2005 18:24
Myscha wrote:
@Henri: Thanks for your help and for LCDInfo!
Glad to see your lcd working. But I think there were still some things I promised to look into but haven't got to do that yet...
PostPosted: Tue May 10, 2005 19:32
Myscha wrote:
You can do a RGB fade. You can control every colour over a poti and regulate every brightness from 0% to 100%.
I'll upload the schematic and pics in the LCDHype-forum in the evening.
Myscha,
If you do post schematic and pics, could you post here as well. I can't read German, so it would be great if you could list it in LCDinfo too. Thanks.
PostPosted: Tue May 10, 2005 20:45
I made a pdf from my schematic today, but forgot to post it and left it at work. I'll do that tomorrow.
I'll post the pics there and try to describe it here in english. If there is anything you don't understand tell me!
I'll post the pic of my light bar the next few minutes in the Hype forum.
It's only a piece of pcb with pads on both sides which are connected through and with a distance of 1.27mm. I soldered 4 times a red, a green and a blue PLCC2 led on it and connected them on the backside. The red ones all in serial, the blue and green ones two in serial, two times parallel. I make my voltage through a 8V voltage regulator with a 1N4148 in the GND lane, so i get 8,7V out of it. 8V would not be enough because the red leds have 2,1V each. 4 wires are going to the bar: one for my supply voltage (8,7V) and a "GND" for each colour.
PostPosted: Tue May 10, 2005 20:51
@Henri
You don't have to hurry - my lcd is working and for now i'm glad about that... ;) The only problem is that i can't make for example a clock over the whole screen, but the rest does work fine. I must "re-think" when i'm working at the screen, but that is ok...
PostPosted: Wed May 11, 2005 8:37
Now i have uploaded the schematic on the Hype forum. I'll draw it with a cad-programm soon, but for now it should be ok...
PostPosted: Fri May 13, 2005 17:02
Myscha wrote:
I soldered 4 times a red, a green and a blue PLCC2 led on it ...
Where did you get the PLCC2 leds?
Also, and don't take this the wrong way, the schematic you posted in LCDHype is really hard to read.
PostPosted: Sat May 14, 2005 11:36
I'm working in an electronic assembling factory, so i got them from there. But here in germany you can also buy in an online shop, for example:
http://www.reichelt.de/inhalt.html?SID= ... =0;TITEL=0
Do you mean hard to read because of the bad quality or because it is complicated?
PostPosted: Sat May 14, 2005 12:53
Hard to read because of quality. From the looks of it, the circuit looks pretty straight forward, but hard to see a lot of the component values/connections. I know you had said you were working on a CAD draw-up, so I will wait for that. Thanks.
Tried the link, but unfortunately, I can't read German :cry:
How much were they?
PostPosted: Sat May 14, 2005 19:28
I'll post the drawing when i finished it.
The red, green and yellow leds cost 0.17 Euro a piece and the blue are 1.28 Euro.
Where are you from? I think there should be also a shop in your country where you can buy leds. I can't imagine that there is none...
PostPosted: Sat May 14, 2005 21:00
I'm in the USA. I wasn't sure if the PLCC2 were a special surface mount package or not. I'll have a look around. Thanks.
PostPosted: Sat May 14, 2005 21:37
PLCC2 is looking like the one here:
You can also take any other size of led if you have place enough in your display. I took that ones because they are very bright and small sized...
PostPosted: Sun May 15, 2005 0:58
Thanks Myscha. Where did you place your LED's? On the sides, middle...? This is a great mod, and hope to use it in a number of things, other than LCD's.
PostPosted: Sun May 15, 2005 23:52
You can place the leds whereever you want. I placed them like that:
---RGB----------RGB----------RGB----------RGB---
I'll try to make better pics next week with the cam at work.
PostPosted: Tue May 17, 2005 21:56
I upped the schematic now - the pictures will follow tomorrow or on Thursday...
