It is currently Thu Oct 08, 2026 22:50
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Tue May 23, 2006 4:47
coorz wrote:
Make sure you didn't sample the SMT versions :lol:
Like i did... :roll: Still usable though.
Hey Coorz, I ended up getting two of the right ones and they didn't cancel the other order, so when they came in I was glad I ordered the other two as well, I mean these things are small. Im talking about the size of dust small, lol.
 Post subject: EL Backlight driver
PostPosted: Tue May 23, 2006 20:38
I got the same LCD. EL backlight requies 100V 400hz. I am in process building the PS for it with Supertex Driver. Like HV850. You can also test EL backlight with standard AC 110V. It is little danger though. But just for testing.
PostPosted: Tue May 23, 2006 23:21
Sonny, do you have the exact data sheet for this display?
PostPosted: Sat May 27, 2006 15:45
Well i got the circuit made i hooked all of it up and still nothing. Im going to recheck all of the wires once I get a chance. has been a long week, lol. hopefully ill find something out when working on it. already switched a couple of wires around that could have been the issue, but dunno still no text. :?:
PostPosted: Sat May 27, 2006 17:44
If it's a transflective display, you should still be able to see it even without the backlight. Post how you have it all wired up and we might be able to help figure out what may have went wrong. Usually, it's almost always in the wiring and/or the software configuration.
PostPosted: Sat May 27, 2006 22:39
Ill try it tonight without the backlight and see what I can find out, maybe I have too uch backlight which is causing the text to not appear. Possible I guess? Ill find out tonight for sure.
PostPosted: Sun May 28, 2006 0:12
I don't think it would be the case of "too much backlight" but more a case of too much contrast (all black) or not enough (all blank). That's why if you can post exactly how you have it all connected up, including your negative voltage supply, it will make it easier to figure out....hopefully :D
PostPosted: Sun May 28, 2006 0:50
well I followed the 2 schematics on here. The negative psu is setup as shown on the previous page. The LCD is connected the same way described in the t6963c wiring schematics shown at the opening of this site for t6963c information. I checked all of the connections and they all seem fine I saw a couple that I soldered badly come loose but reattached them with no problem. check the rest and they are rock solid connected.
PostPosted: Tue May 30, 2006 17:15
when I first test LCD, i use ATX -12V with 10k pot. You can turn pot and all the pixels on LCD will shows up without EL Backlight ON. I am now using a NE555 with 7812. I noticed that when negative go below 7, it will not displays anything.
Users browsing this forum: No registered users and 280 guests
