It is currently Wed Nov 04, 2026 19:51
PostPosted: Sat Feb 12, 2005 3:50
Hello all.
I just bought the Noritake Gu128x32 311 lcd and I have a problem with my ground pin. I know that if you short pin 2 to ground the VFD should go through a selftest.
The problem is that the display go trough selftest just by connecting pin 3 (ground) I don´t have to short pin 2.
Please help me!!
PostPosted: Sat Feb 12, 2005 12:17
Do you have anything connected to the data connector ? Just that as you have the selftest pin also in the data connector you aren't accidentally shorting it to ground there ?
PostPosted: Sat Feb 12, 2005 14:19
No, just power and ground are connected.
Do you know wich pin in the data connector that is the selftest pin?
PostPosted: Wed Feb 16, 2005 0:37
Looks like I remembered wrong. This display doesn't seem to have the self test pin in the data connector at all like some other Noritake displays.
