It is currently Fri Nov 06, 2026 2:26
PostPosted: Sat Feb 26, 2005 8:59
I have a solomon 4x40, LM1194SGL it has a 16 pin connector and it does not work with the standard hookup I have used for all of my other displays. in fact the controller chips got warm So i am sure the wiring i have is wrong, I'm hitting alot of dead ends, Can anyone help? It has 2 HD44780A00 controlers on it with a handfull of little chips that i believe are just for driving the lcd. The numbers on those chips are all the same:
NJU6407CF
JRC
P7009C
Can anyone help?
something else i noticed is that the chip configuration seems to look more like alot of serial LCD's I have seen, So maybe this is a serial lcd?
I can also post pictures if that would help
PostPosted: Sat Feb 26, 2005 18:33
found this out about it.. from reading the Spec Sheet for the HD44780U
it appears to be the same datasheet for the HD44780A00
But I got this for it Playing with a multimeter
Pin Fucntion
01 D7
02 D6
03 D5
04 D4
05 D3
06 D2
07 D1
08 D0
09 Enable IC1
10 NOT R/W
11 RS
12 V5
13 GND
14 +5 volts
15 Enable IC2
16 NC
Users browsing this forum: No registered users and 69 guests
