It is currently Mon Nov 09, 2026 16:14
 Post subject: LCD 4 BIT
PostPosted: Sun Jan 26, 2003 15:12
Hello,
I got a LCD GRAPHIC 128x128 and I would like to use a bus 4 bit instead 8 bit.
It is possible ?
Thank
PostPosted: Sun Jan 26, 2003 20:33
Ok, so you have regular 8 bit display that you would like to use with only 4 data bits (like with HD44780 for example) ? I'm asking this as I'm not 100% sure what you meant.
Any datasheet of the display or do you know which controller it has ?
 Post subject: graphic lcd 4 bit
PostPosted: Sun Jan 26, 2003 23:56
I have lcd 128x64 ks0108 chip based (not 128x128 ops!) I ask you if is possible to use it with only 4 data bits, or if exist graphic lcd with only 4 data bits.
I am using a microcontroller for my project but I would like to save 4 I/O
Thank
PostPosted: Mon Jan 27, 2003 10:57
I'm not aware that it would be possible to use 4 bit mode with KS0108, at least I haven't seen anything about that in the datasheets.
