It is currently Tue Nov 24, 2026 17:06
PostPosted: Thu Mar 24, 2005 9:10
I want to buy new Hitachi LMG7412PLFF LCD Display for replace Display Module in Control Unit. But I can't find. Please suggest me where can I get it, or other compatible module. The control unit connect with LCD by CN3 Connector (10 Pins) not genneral 20 pins (CN1)
I cannot find datasheet for this model. I have only LMG7420PLFC-X from Hitachi US and sp14n002, sp14n003 from Hitachi UK that use LC7981 controller, but on LMG7412PLFF use LC7940N x 3 and LC7942N x 2.
It is very important because the control unit is very expensive (over 5000$US)
thank you very much for your help.
Vasu Udompetaikul.
 Post subject: more Information
PostPosted: Thu Mar 24, 2005 9:14
it is 240x128 LCD Graphic Display
PostPosted: Mon Mar 28, 2005 18:50
You might be able to use some lcd with compatible interface. But the pinout and details of the connector should be known to be able to make the connections. Based on the 10 pin connector and the driver IC's on the board sounds like the lcd itself doesn't have the controller IC in it.
LMG7412PLFF with google gives some hits for a datasheet but unfortunately those links are not working anymore.
 Post subject: LMG7412PLFF
PostPosted: Fri Dec 16, 2005 16:11
Dear Vasu Udompetaikul;
Please contact me at 02-865-3350 about LMG7412PLFF.
Pitak
pitak@w-sathaworn.com
PostPosted: Thu Aug 10, 2006 6:21
If your module need to replace again. You can contact me! I know where can found this module and the the pricing is very low!
PostPosted: Thu Aug 10, 2006 6:22
My email is southeng@biznetvigator.com
Users browsing this forum: No registered users and 42 guests
