| toshiba TLX-1741-C3B what do i need to get started http://forum.lcdinfo.com/viewtopic.php?f=6&t=1140 |
| Author: | waroffice [ Fri Apr 01, 2005 15:52 ] |
| Post subject: | toshiba TLX-1741-C3B what do i need to get started |
I have just aquired a Toshiba TLX-1741-C3B for my media centre PC project. Im just not sure what i need to get started.....this is what i think i need 1) wire up the control port on the thing to the specs of the schemeatic for the T6963C on this site. 2) find me a -8v power source. (maplins or RS) 3) a power source for the backlight i have an invertor from a scanner that should work. is there something im missing or if someone could point out where i can get the right power sources from that would be grand.... Thanks |
| Author: | Henri [ Sun Apr 03, 2005 11:39 ] |
The pinout of that display seems to match the TLX-711A here: http://www.skippari.net/lcd/t6963c_schem.html EXCEPT that pin 20 is REVERSE input. If you connec this to +5v you get positive image and if you connect it to ground you get negative image. Also the typical VDD-VEE voltage is 18.5V in the datasheet. This would mean that with +5v VDD you need at least -13.5V VEE negative voltage. |
| Author: | waroffice [ Mon Apr 04, 2005 9:44 ] |
where could i get a power source from and what am i looking for, could i use a transformer from anuthing i find around the house and how to i get a -13.5v from a transformer? Sorry about 20 questions i didnt do much electronics in school but i did a bit even thought it was 9 years ago |
| Author: | waroffice [ Wed Apr 06, 2005 17:49 ] |
i found an old HP printer power surply, says 18v 1.1Amps is this what im looking for in the -18v stakes..... just a thought |
| Author: | waroffice [ Tue Jun 07, 2005 9:49 ] |
just to bump this thread up to the top, i am thinking of getting this project back on. I am assuming to get the -13.5v i need i just conect it to the - side of the transformer or am i way out as thats all i can think of. |
| Author: | CMAN101 [ Wed Jun 08, 2005 20:30 ] |
You can trying using a 5Vdc Pwr supply and then a -15V voltage regulator connect to a Trim, so that your are able to adjust contrust. http://www.skippari.net/lcd/t6963c_schem.html like described in the link, just look for a regulator that will meet your needs, you will have build a simple circuit on a PCB to get the voltage though; its the only way! |
| Author: | waroffice [ Thu Jun 09, 2005 9:49 ] |
thanks for your reply. Figure 3 looks right for me, i have tinkered with protoboard before what size would be enough for this 6x4in? Thanks again |
| Author: | waroffice [ Thu Jun 09, 2005 11:38 ] |
looks like my electronics skils are not upto the job, is anyone willing to put together the correct circuit im willing to pay for such services |
