| Good circuit making programs http://forum.lcdinfo.com/viewtopic.php?f=6&t=1152 |
| Author: | jaakko100500 [ Fri Apr 08, 2005 18:39 ] |
| Post subject: | Good circuit making programs |
Hello, this may be in the wrong forum etc. but anyways: I've used PowerPCB at school, but can't find it anywhere on the net. So what programs do you guys use to draw ur circuits? Atleast auto-routing is a must in a drawing program. |
| Author: | Deep Blue [ Fri Apr 08, 2005 19:53 ] |
Eagle, there's a free version with these limitations: The following limitations apply to the EAGLE Light Edition in general: * The useable board area is limited to 100 x 80 mm (4 x 3.2 inches). * Only two signal layers can be used (Top and Bottom). * The schematic editor can only create one sheet. If you want more board space and are willing to pay, you can get a version with non-commercial lisence, or you can get the full version, which costs more. It also has linux(which i use) and MacOsX versions. http://cadsoft.de/ |
