It is currently Sat Nov 07, 2026 20:18
PostPosted: Thu Apr 28, 2005 16:30
got the pinout for an sharp lcd but dont understand what they want to tell with it.
Flat Panel Connections CM112/110 Connections
Signal Pin Pin Signal Comments
S 1 <> 11 FLM -
CP1 2 <> 10 LP -
CP2 3 <> 13 SHFCLK -
Vdd 4 <> 1 Vddsw -
Vss 5 <> 6 GND
Vee 6 <> 4 Vee- -
Vss 7 <> 9 GND -
DU0 8 <> 18 PNL3 Data bits are in reverse order.
DU1 9 <> 17 PNL2 -
DU2 10 <> 16 PNL1 -
DU3 11 <> 15 PNL0 -
DL0 12 <> 22 PNL7 -
DL1 13 <> 21 PNL6 -
DL2 14 <> 20 PNL5 -
DL3 15 <> 19 PNL4 -
whats about the DU,DL,Vss where is Hsync and Vsync?
PostPosted: Thu Apr 28, 2005 19:47
Hey antiHero.
Think we are looking at more or less the same document.
This is what i have found in other docs, anybody correct me if i'm wrong.
SHFCLK clocks in 8 pixels from DU & DL.
LP must be high for the last SHFCLK on the line, ie similar to h-sync.
FLM must be high for the whole of the last line, similar to v-sync.
Vss=GND
Vdd=+5V
Vee=-17V
Re DU/DL:
The screen is devided into upper half and lower half. With each SHFCLK 8 pixels are clocked it, 4 in the upper half(DU0-DU3) and 4 in the lower half(DL0-DL3). The four pixels are next to each other, on the same line.
Hope this helps...
Which LCD is this?
BTW, i have a very bad quality PDF of another Sharp LCD that explains the wave forms... But it isn't very readable...
Thanx,
r
PostPosted: Fri Apr 29, 2005 10:17
thats a lm64p722. the one i got is lm64p702 but the722 is the closest i can find. they are the only one with 15 pin plugs. want to know if i can run this tru a vesa vga card as controller.
PostPosted: Fri Apr 29, 2005 10:42
Beware: My Sharp(LM64P83) also has 15 pins but in a slightly different configuration.
As to connecting it to a VGA card, not easily, unless the card has provision for an LCD. You can look at:
http://eio.com/lcdconnect.htm
