| GU256x64-355 compatible with GU256x64-372? http://forum.lcdinfo.com/viewtopic.php?f=6&t=1184 |
| Author: | vitovitez [ Tue May 03, 2005 13:02 ] |
| Post subject: | GU256x64-355 compatible with GU256x64-372? |
Hi, I have one Noritake GU256x64-355. Is it compatible with the wiring and the drivers for GU256x64-372? Sorry, but no datasheet by now. Thanks. |
| Author: | Henri [ Wed May 04, 2005 0:08 ] |
If I had to guess I'd say yes, the pinout and wiring and driver to use are the same. But I'm not going to give you 100% quarantee. |
| Author: | vitovitez [ Wed May 04, 2005 9:01 ] |
Thank you for your fast answer. I will try and keep you informed. As I have never tried to connect vfd's (or lcd's), first I will try some lcd's (I do not want to fry my supercool GU256x64-355). |
| Author: | One~Zero [ Thu May 05, 2005 3:10 ] |
I have a GU256x64-352 which I used the -372 scheme for and it worked. However, to make completely sure (since you don't have a pinout) you could get the data sheet for the controller ic, and work backwards from there to find out where the signals go to on the connector. It might take a little bit of time, but it would be worth it. |
| Author: | vitovitez [ Thu May 05, 2005 9:55 ] |
I have now the data sheet. The pin assignment is the same as in GU256x64-372. I will try this weekend (hopefully). Thank you for your support. |
| Author: | One~Zero [ Thu May 05, 2005 12:39 ] |
Great! The VFD is a lot easier to connect than an LCD by far. |
