It is currently Tue Nov 10, 2026 22:51
PostPosted: Wed May 25, 2005 16:44
I'm got this lcd from canon fax l3300i ,But,I don't have any information for this lcd.
Somebody help me please......
Full view
Front view
Back view 4x OkiM5260 Chips)
Chips Oki M5260 x 4
EL BackLite Power Inv
Thankyou for any answer
PostPosted: Thu Jun 02, 2005 10:54
You could try tracing the pinout to the connector with the help of the column and row driver IC datasheets.
PostPosted: Thu Sep 15, 2005 6:44
I can help you a little by telling you that the 4xM5260 chips are row-by-column drivers. But it also looks like there are shift registers on there. It's gonna take a lot of work to figure that one out because there isn't a single-chip controller on it.
PostPosted: Sat Sep 17, 2005 2:00
Can't be 100% certain, but I think someone else had a copier display that used the HD61830 controller (LC7981 compatible). Hard to say for sure though, but with only 8 pins, very possible it will use the LC7981/HD61830.
You don't happen to still have the rest of the copier, do you?
Users browsing this forum: No registered users and 16 guests
