It is currently Fri Nov 13, 2026 8:52
PostPosted: Thu Jun 02, 2005 10:44
I have a ks0108 display which i have wired according to the schematics on this website, my problem being that when i use the ks0108 test program the display is streched horizontally, it appears to be inserting a blank line between every column.
Initially it had a lot of static bits but i sorted that by putting noise limiting caps over the control lines.
I have tried all the different Parrallel port settings in the bios but this makes no difference.
Any one have any ideas or even seen the same problem before
PostPosted: Thu Jun 02, 2005 10:48
Sounds like the display is for some reason interpreting one additional enable pulse so it write two bytes instead of one. I believe this could also be something about the wiring. You could also try changing the delay setting in the driver configuration.
PostPosted: Tue Jun 07, 2005 0:42
i checked it on my laptops LPT port and it works fine so i dont know if its noise off my pc or my motherboard or what causing the problem when i arent busy at work ill check it on the logic analyser.
