| Toshiba TLX 1741 C3M wiering, testing http://forum.lcdinfo.com/viewtopic.php?f=6&t=123 |
| Author: | joed [ Mon Feb 03, 2003 0:09 ] |
| Post subject: | Thosiba TLX 1741 C3M wiering, testing |
Hi, I am new to this Forum and hope I can get some answers. I became from a Friend a Display named TLX-1741-C3M from Thosiba. I have browsed the net from Info about this and how to connect this to my PC. I am happy to found this Forum an the Software from henry. The PDF Datasheet looks like the TL-711-A LCD and I have wired it like your scheme "Connecting Toshiba TLX-711A display to LPT port ". Only the Contrast Voltage needed seems to be -15 V. Now my Questions, sorry but I dont know many about LCDs 1. At this time I havent the - 15 Volt Contrast Voltage Can I test the Display without this Voltage if It Works? Pherhaps take -12 Volt from the ATX Power Cable? Or only with Software to check the correct wireing? 2. At this time I have no 100Volt for the Display lightning, can I see if the Display works when I use a strong Ligthsource from the Front? Sorry for my bad english and my pherhaps silly Questions. Thanks in Advance, Jochen |
| Author: | Marty [ Mon Feb 03, 2003 7:40 ] |
Your questions are not silly. We all had to learn about LCD's from somewhere, and I too had many of the same questions. Quote: Can I test the Display without this Voltage if It Works? Pherhaps take -12 Volt from the ATX Power Cable? Or only with Software to check the correct wireing? I don't think that will work. Quote: 2. At this time I have no 100Volt for the Display lightning, can I see if the Display works when I use a strong Ligthsource from the Front?
Well in theory you could put the light behind the LCD, but this is not possible usually as the LCD is mounted on a board. But sometimes you can get a faint view of what is being displayed by using a light from the front. But this is even less likely with the wrong contrast voltage. I presume you have CCF back lighting and need an inverter. Sorry about all the bad news but trying to get it to work is half the fun. Good luck, Marty. |
| Author: | joed [ Mon Feb 03, 2003 9:35 ] |
Quote: Sorry about all the bad news but trying to get it to work is half the fun.
Good luck, Marty. Thanks for the answer. I donts think thats bad news Thanks a lot, Jochen |
| Author: | joed [ Fri Feb 07, 2003 1:03 ] |
Knows anybody which Chip can be damaged? The name of the Display is TLX-1741-C3M. Good night, Jochen |
