It is currently Fri Nov 13, 2026 22:31
PostPosted: Sat Jun 18, 2005 14:15
I have checked all the pinouts of this display and proved them to be
common to most other displays acording to the T6963C datasheet.
I get nothing but random horizontal lines across the display, and
LCDinfo will show solid vertical lines where it is trying to display graphics
but too large for the screen.
I have checked and rechecked the wiring and as the lines seem to move around when the info changes I am suspecting that I am specifying
an incorrect size.
Does anyone know what size display this is as I have tried all software
I could find without much luck.
PostPosted: Sat Jun 18, 2005 18:53
Do you have a datasheet for your display?
PostPosted: Sat Jun 18, 2005 22:35
Check wiring again and again and again.
 Post subject: could be faulty
PostPosted: Tue Jun 21, 2005 15:50
I have lost count on the number of times I have re-checked the wiring,
even leaving it to the next day didn't help.
I followed another thread from this forum
http://forum.lcdinfo.com/viewtopic.php?t=576&start=0&postdays=0&postorder=asc&highlight=
which looks to be the same as I have worked out.
I have noticed that although the lines across the display seem to be random, they apear to be the bottom most line of each character in text mode, and a Bitmap shows up as though lines are missing.
I am now thinking that the row generator chip T6A40 could be at fault.
 Post subject: Replaced
PostPosted: Thu Jun 30, 2005 10:41
Looks like it was a faulty display. Tried another and it works fine.
I have a small black bleed mark on the screen even with no power, if anyone knows how to fix this, let me know.
