It is currently Tue Nov 10, 2026 20:11
PostPosted: Fri Sep 02, 2005 0:57
Ok i deal mostly in phasechange cooling for high end Computer's..well 1 of the unit's im moding has a "1602H REV .1 lcd on it,9it only display's number's and text..id like to put a true lcd on it and write some software to make use of this new found idea..im a coder so software isent a problem..but i need to know what LCD will be the best drop in replacement for the unit, it has 16 pin's all in 1 line and has a built in controller..what are my option's here?
Thank's BB
PostPosted: Fri Sep 02, 2005 4:21
1602 sounds likea HD44780 character LCD. I don't think you can drop in replace it with a true graphical one. Why not get a graphical one and use lcdinfo or lcdstudio to show system info?
Also possible are certain character VFD drop-in replacements from Futaba or Noritake.
PostPosted: Sat Sep 03, 2005 1:17
Because these phasechange cooler's are running between -35 and -60*c and they need there special controller's that are built to monitor these temp's...are there no HD44780 graphical lcd's witht he same controller/interface? i can change the connector for the unit that's not a problem.
PostPosted: Sat Sep 03, 2005 1:19
I have a few noritake itron CU20025ECPB-W1J VFD's but there lame..im looking for a sexy blue LCD unit for these phasechange cooler's
Users browsing this forum: No registered users and 98 guests
