It is currently Tue Nov 10, 2026 21:57
Would you be interested in a LC7981 controller
Poll ended at Tue Oct 04, 2005 12:40
yes 100%  100%  [ 1 ]
no 0%  0%  [ 0 ]
Total votes : 1
PostPosted: Sun Sep 04, 2005 12:40
A couple people have inquired about HD61830/LC7981 controllers for their LCD's. I started a prototype board and currently have one running an Optrex 480x64 display. The board consists of the LC7981 (compatible with the HD61830 controller), onboard variable negative voltage generator and contrast control. I want to find out how many other people may be interested in these controllers so I can get an approximate cost for purchasing parts and getting the boards made. The cost will be about $55 US each.
Features:The LC7981 controller has a maximum resolution of 640x256. It takes an 8-bit data interface and converts it into a upper and lower (D1 and D2) serial data stream for your LCD.
8-bit MPU interface
Graphic mode: 512k dots (2^16 bytes)
Character mode: 4096 characters (2^12 characters)
Internal character generator ROM: 7360 bits
160 types of 5x7 dot characters
32 types of 5x11 dot characters
Total 192 characters
The LC7981's are more so for some older type displays that require the 2-bit interface. If any of your spec sheets for your displays show the D1 and/or D2,FLM, M(A/B), CL1, CL2 (CP/LP) then the LC7981 board will more than likely support those displays.
Pic of controller (the board will look similar to this, but without the cut traces and blue wire...there is a reason to prototype before production :D :
Here is the display I have running with this controller:
I've posted this poll in a couple of different sites. So, please, if you answer on one site, don't answer again on the others. Thanks.
PostPosted: Tue Sep 06, 2005 6:30
whats the highest pixel size this controller can do?!
PostPosted: Tue Sep 06, 2005 11:22
See edited description above... :oops:
