| LC7981/HD61830 Controllers http://forum.lcdinfo.com/viewtopic.php?f=6&t=1343 |
| Author: | One~Zero [ Sun Sep 04, 2005 12:40 ] |
| Post subject: | LC7981/HD61830 Controllers |
A couple people have inquired about HD61830/LC7981 controllers for their LCD's. I started a prototype board and currently have one running an Optrex 480x64 display. The board consists of the LC7981 (compatible with the HD61830 controller), onboard variable negative voltage generator and contrast control. I want to find out how many other people may be interested in these controllers so I can get an approximate cost for purchasing parts and getting the boards made. The cost will be about $55 US each. Features:The LC7981 controller has a maximum resolution of 640x256. It takes an 8-bit data interface and converts it into a upper and lower (D1 and D2) serial data stream for your LCD. 8-bit MPU interface Graphic mode: 512k dots (2^16 bytes) Character mode: 4096 characters (2^12 characters) Internal character generator ROM: 7360 bits 160 types of 5x7 dot characters 32 types of 5x11 dot characters Total 192 characters The LC7981's are more so for some older type displays that require the 2-bit interface. If any of your spec sheets for your displays show the D1 and/or D2,FLM, M(A/B), CL1, CL2 (CP/LP) then the LC7981 board will more than likely support those displays. Pic of controller (the board will look similar to this, but without the cut traces and blue wire...there is a reason to prototype before production
Here is the display I have running with this controller: I've posted this poll in a couple of different sites. So, please, if you answer on one site, don't answer again on the others. Thanks. |
| Author: | shuichinz [ Tue Sep 06, 2005 6:30 ] |
whats the highest pixel size this controller can do?! |
| Author: | One~Zero [ Tue Sep 06, 2005 11:22 ] |
See edited description above... |
