| SED133x to controllerless LCD *Updated April 20th* http://forum.lcdinfo.com/viewtopic.php?f=6&t=1348 |
| Author: | coorz [ Wed Sep 07, 2005 16:13 ] |
| Post subject: | SED133x to controllerless LCD *Updated April 20th* |
Here's a quicky on how to connect SED133x to controllerless LCD's. Can i use this controllerless LCD i found? Checklist: - Datasheet! - Size must not exceed 640x256, anything bigger forget it! - Must be 4-bit (D0~D1) if you want to use SED133x - check if it's easy to solder; FFC or small pitch solder pads can be hard. - don't forget the DC-DC converter (negative voltage generator) for contrast control, if it ain't onboard you gotta build it - backlight requirements; LED and CCFL are easy. EL too but those mini-inverters might be hard to source. LCD to SED-board pin layout As manufacturers have different naming for the pins i have collected as many as possible name variations per pin. Code: SED133x LCD
XD0 D0 XD1 D1 XD2 D2 XD3 D3 XSCL (CL2) CP (CP2, SHFCLK, DATA SHIFT) LP (CL1) LP (CP1, DATA LATCH, LOAD) WF (M) M (AC Drive signal, alternate signal) (if applicable) YD (FLM, DIN) FLM (S, FRM, FRAME, FRAME PULSE, Scan start-up) Some LCD's have a INH(X) or /DISPOFF pin, this one's tied to +5 normally. Obviously you'll need to wire the voltage pins too. Regarding the negative voltage supply for contrast control (DC-DC converter), here are some namings: Vo=Vadj Vlc=Vee Vdd / Vcc=+5v Vss=GND, GROUND Where to buy SED133x controller boards; Henri (if he feels like) over a LCDinfo in Finland, he's got some custom built boards for the SHARP LM32007T and OPTREX DMF50480 qVGA's. Mark de Jong in Germany LC-Design Germany, has higher level SED boards too, not supported by Studio but perhaps of interest for the die-hard LCD freaks. Also loads of interesting LCD related goodies. MPI in the USA, also sells DC-DC converters EIO in the USA SED133x DIY schematic: Mark de Jong provides the schematics over at his website, downloads>schaltplan/anleitung platine. You may thank Mark. Some others are floating around on the net, give it a search. Or just check the SED datasheet for application notes. Backlight issues coming soon DC-DC converters (negative voltage generators) - A cheap solution can be found here, thanks Razor. - Another easy one here with few components, thank Chatlie - free of charge but untested and at own risk; your ATX powersupply has -12 on the BLUE line. More to come I did it! But why does it look ..crappy? congratulations! you managed to hook up that nice big 640x200 display but lo' and behold it looks like sh*t Here's why. The bigger the display the more distortion you will notice. In general 320x240 is the sweet spot, and therefore the most popular. Feel free to correct me or add your own comments. |
| Author: | harilcd [ Mon Nov 28, 2005 13:06 ] |
| Post subject: | hai solution required urgently |
hai coorz, i had seen ur mail, and it seems that ur have good experience in dealing with controllerless lcds i have a problem with my readymade lcd module which has got a inbuilt controller(lc7981) +sram .(192x128 lcd panel) to interact with the sram i have to first send a command word and then the required data. thus for 192x128 lcd panel i have to send 192x128)/8 command+data word sets and also control the control signal like "RS", "E" etc. Please suggest me what i have to do, as this is degrading the processor performace to great extent |
| Author: | coorz [ Wed Nov 30, 2005 21:10 ] |
I'm sorry but i'm not that good, I can understand basic stuff, but not too technical! |
| Author: | rommelm [ Thu Dec 22, 2005 4:21 ] |
Do you think that Nokia 6600 LCD is controllerless.. cause nobody knows the controller used. |
