It is currently Tue Sep 01, 2026 12:25
 Post subject: -7,8V to -12V (MC34063)
PostPosted: Fri Feb 14, 2003 17:50
Hello!
I have the Sharp LM24014 Display!
The LCD needs -12V.
If I use the circuits with the MC34063 form http://www.skippari.net/lcd/t6963c_schem.html I get -7,8V.
Does anybody to wich value i must change the 5,6KOhm and 27kOhm to get -12V?
Thanks.
Bye
Wolfgang
PostPosted: Fri Feb 14, 2003 22:37
Are you going to try and actually make this? The charge pump device is quite exensive. There are other easier was to do this.
Your computer PSU has -12v for example. Or you could use the transformer idea http://www.skippari.net/phpBB2/viewtopic.php?t=19
Marty
PostPosted: Sat Feb 15, 2003 2:44
Marty
I built it. The MC34063 is ca. 0,5€. But I found a solution. In this document: http://www.onsemi.com/pub/Collateral/MC34063A-D.PDF
I change the Rs by this formula |Vout| = 1.25 * ( 1+ R1/R2 ) to R1=127KOhm and R2=16,2KOhm.
And now the LCD works fine.
Bye
Wolfgang
PostPosted: Sat Feb 15, 2003 11:50
I'm glad that you already found the solution. I would have pointed you to that same formula. :wink:
PostPosted: Thu Feb 27, 2003 12:01
too late, but for others http://www.nomad.ee/micros/mc34063a/index.shtml
online design tool for mc34063 as step-up, step-down, or inverting
Götz
PostPosted: Thu Feb 27, 2003 13:17
Götz wrote:
Nice one. Thanks for the link Götz.
Users browsing this forum: No registered users and 156 guests
