It is currently Tue Nov 10, 2026 19:13
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: nokia 5210
PostPosted: Wed Nov 02, 2005 21:06
i Found my old 5210 any one has any idea where i could find specks for this display?
i used google but couldt find anything use full :(
PostPosted: Wed Nov 02, 2005 21:15
and i found these from phone
DF7_06
9854572
somethink like "A" and "S02" and smol "27b" (AS0227b)
R394V-0
PostPosted: Thu Nov 03, 2005 18:53
Any one any help??
PostPosted: Thu Nov 03, 2005 23:59
I've read, that the display is the same with other nokia's, but the result is reflected.
gsmaster :)
PostPosted: Fri Nov 04, 2005 1:23
I've been looking for informations about nokia displays for a long time, and What I found is that all uses the same controller (PCD8544) and the PN is LPH7366 for some Nokia display. There are lots of projects with them.
http://sandiding.tripod.com/Bertys.html
http://rifer.narod.ru/usblcd.html
PostPosted: Fri Nov 04, 2005 1:51
according to the data sheet your display seems to be a LPH7779/7677 compliant one (8 pins)
@dantasad_28: lph7366 has 9 pins ...
but all of these are driven by the same controller (pcd8544 or compliant)
/mrwastl
PostPosted: Fri Nov 04, 2005 15:34
DAM im soooo confused :D
im not wery fimiliar whit these ports and pins,
and i hawe so poor english :(
is LPT = 25pin printer port?
PostPosted: Fri Nov 04, 2005 17:15
where did you read LPT?
LPH != LPT
LPH7779, ... are model names. if you would have read some of the existing projects you would have read about those different model names.
some urls:
(dantasasd_28 already posted a link to Bertys pages):
http://sandiding.tripod.com/lcd.html
my own project: http://serdisplib.sourceforge.net
(use http://serdisplib.sourceforge.net/ser/pcd8544.html for your display)
and many others (some are listed in the page above)
/mrwastl
PostPosted: Sat Nov 05, 2005 11:32
http://sandiding.tripod.com/lcd.html <-- end of that pake says
"Lpt port connectivity"
And link goes to....
HERE ----> http://serdisplib.sourceforge.net/ser/pcd8544.html
Can i use that wiring??
if not, any of u hawe direct wiring quide and now i read those links :D
PostPosted: Fri Nov 18, 2005 1:19
NOKIA 5210 pinout tested
inverted display can be seen in a digital clock application.
Perhaps Henry could add a modified driver for these displays, so they can be used with LCDinfo.
gsmaster :)
PostPosted: Tue Nov 22, 2005 17:45
DAM i all ready left that project and ordered 2x16 lcd :(.
http://www.bebek.fi/kauppa/tuotekuvat_u ... 0a00d7.jpg
and i would realy like to see those picks but they wont load up.
edit. server was down i ques.
PostPosted: Tue Nov 22, 2005 22:00
i thinked that i could use 2 LCD, so i started to selder first but noticed that i cant do it :D
So pin out goes like?
RES => LPT pin 4
Vout => LPT pin ?
GND => LPT pin ?
CS => LPT pin ?
D/C => LPT pin 6
SDA => LPT pin 3
SCL => LPT pin 2
VDD => LPT pin ?
i all ready soldered those :D so i hope that is ok.
PostPosted: Tue Nov 22, 2005 22:47
With LCDInfo you can use whatever pins from the LPT datalines (2-9) and then set the same pins in LCDInfo.
You also need to connect a small capacitor (ceramic or polyester) between the VOUT & CS pins and the CS pin also to GND.
For example:
RES => LPT 4
GND => LPT 18-25
D/C => LPT 6
SDA => LPT 3
SCL => LPT 2
VDD => LPT 9 (to be safe you could put a diode between VDD & LPT pin 9, the stripe facing away from the LPT port.)
VOUT => capacitor => CS
CS => GND
PostPosted: Wed Nov 23, 2005 19:13
i just soldered alll those and nothing ? hawe i some think to remember?
PostPosted: Wed Nov 23, 2005 22:33
Propably doesn't work because the PCD8544-driver in LCDInfo is for a different model. Unless someone writes a new one.
