It is currently Sun Nov 22, 2026 20:14
PostPosted: Tue Nov 22, 2005 10:41
I have a circuit that gives me -12v DC. I have two small problems though:
-> The maximum for the drive voltage on my lcd is -10v. How can I step down the -12v to -10v or lower?
-> Is 1A likely to kill my 128x64 LCD? Should I just get a massive resistor and whack it on?
PostPosted: Wed Nov 23, 2005 3:47
It's MORE than likely...it WOULD kill your LCD. What type of display is it? And do you have a data sheet. That would be very helpful. :D
PostPosted: Wed Nov 23, 2005 9:55
I have a 128x64 glcd; model number CM12864-10. It's from Futurlec; there is a partially translated piece of datasheet here. The controller is T6963C.
What would be a good current? I have an AT psu from an old computer that gives 500mA@-12v if that is better.
PostPosted: Fri Jan 11, 2008 13:24
hi penjuin,
I also bought the same LCD from Futurlec. Did you know you can go to the americian futurlec site www.futurlec.com and down load the Toshiba T6963 driver data sheet. Your -12V could be used on the LCD but you would need to connect the earths together with the 5V supply and on the -12V supply use a resister and zener combination to clamp the voltage at -10V. I dont thinks the -10V Vo connection would pull any more than 20-50mA, as the LCD can only dissapate so much heat. :)
Futurlec say this is a 5V LCD but I don't think it is, I think it is a 5V,-10V display - Gruuuuuuuuuu. :(
I would be interested how you go with your project, are you connecting it to a PIC?. If you are we could share some code.
PostPosted: Mon Jan 21, 2008 12:56
I have been working on a 5V to -10V power supply for the LCD and I finally finished it and it works. If you want a kit for this power supply you can contact me at marni@alphalink.com.au
PostPosted: Sat Oct 20, 2012 14:19
Update to past comments
The CM12864-10 is actually a single 5V power supply LCD display.
The Vo noted on the futurlec data sheet is an output.
Dont connect a power supply to it or you will probably blow it up, like I did.
Connect the Vo and Vss to the ends pins of a variable resistor.
Use 20K to 50K ohms variable resistor. A non linear resistor mabe a good choice, make sure its around the right way.
Connect the variable resistor slider pin to Vee(FG) and good luck
Futurlec, :)
