It is currently Thu Sep 24, 2026 19:14
 Post subject: Optrex DMF666AN
PostPosted: Sat Dec 17, 2005 7:32
DMF666AN K-EW1 E91964 3134L
OPTREX JAPAN
88Z2M3
I picked up this display earlier today for $4, so I'm not expecting much from it... but if I could get it to work, it'd be pretty bitchin'.
What I've got so far is that there's a single 18x1 header on it for data and I've traced out the two pads that control the backlight.
There are three HD61105 controller ICs and 16 HD61104 collumn ICs onboard.
LAYOUT;
 ____________________________________________________________________
|    ____    ____    ____    ____    ____    ____    ____    ____    |
|   |1104|  |1104|  |1104|  |1104|  |1104|  |1104|  |1104|  |1104|   |
|   |____|  |____|  |____|  |____|  |____|  |____|  |____|  |____|   |
|                              _________                             |
|   |***************|         | HD61105 |                            |
|   |***************|         |_________| DMF666AN K-EW1 E91964 3134L|
|   |*****STUFF*****|                        OPTREX JAPAN            |
|   |***************|                      _________                 |
|   |******|    ..................        | HD61105 |    _________   |
|   |******|    ||||||||||||||||||        |_________|   |         |  |
|                                                       | HD61105 |  |
|                                    88Z2M3             |_________|  |
|____________________________________________________________________|
**'STUFF' consists of various 74HC ICs, resisters, and capasitors.
**Board is scattered with test points
I've googled about and found some old forums where people have asked for any information, but recieved no reply, so I'll try my luck here.
Any datasheets/speculations/information at all is welcome [ as is kudos on the ASCII art ;) ].
Cheers.[/code]
PostPosted: Sat Dec 17, 2005 20:35
http://chips.amphus.com/chips/pdf/230dm.pdf
That PDF tells me that this display has a 640x400 resolution.
... niiiice.
PostPosted: Sun Dec 18, 2005 19:11
http://www.eio.com/public/lcd/1085.html
640x400 dots (2x640x200 dual screen)
VDD 5V
VCC-VEE approx 25V (max 28V) (stabilized)
VCC-Adj approx 23.6V (adjustable)
-> negative voltages ref to GND!
Pins
1 FLM
2 LP
3 CP
4 M
5 Vadj
6 VCC
7 VSS
8 VEE
9 DU0 (data upper half bit0)
10 DU1 (data upper half bit1)
11 DU2 (data upper half bit2)
12 DU3 (data upper half bit3)
13 DL0 (data lower half bit0)
14 DL1
15 DL2
16 DL3
17 P/N (positive negative image)
18 n.c. (no connection)
19 EL-foil
20 n.c.
21 EL-foil
GOT IT!
Now, because it's two panels in one, can LCDInfo drive it? Also, how would you guys suggest I go about wiring this baby up to the LPT port? Is it possable?
PostPosted: Sun Dec 18, 2005 21:29
You need a SED1335 controller and this;
http://forum.lcdinfo.com/viewtopic.php?t=1348
PostPosted: Mon Dec 19, 2005 0:03
I would need to double the amount of RAM if I were to build my own controller, correct?
128k would be fine for a 640x200px display, but because it's a 640x400px display I'd need 256k.
Would I need to deploy two controllers [ top/bottom fashion ], or would/could I piggy-back the RAM on Mark de Jong's circuit?
PostPosted: Mon Dec 19, 2005 0:10
I know the limitations of the SED1335 is 640x256, it might be possible to drive it all with latches, but i don't know how to do that.
PostPosted: Tue Dec 20, 2005 5:55
How do you mean, drive it all with latches?
Who would know how to do that?
If I tie the clk and latch pins of two SED controllers, wouldn't they be in sync and then I could get one to drive top half and another to drive the bottom half?
PostPosted: Wed Dec 21, 2005 0:56
Better yet, is there a chip that wires up like the SED1335, but can drive a larger display?
PostPosted: Thu Dec 22, 2005 0:49
Would I be able to drive this display with a VESA port?
VESA Pinout;
Pin    Name    Description
1    PD0    DAC Pixel Data Bit 0 (PB)
2    PD1    DAC Pixel Data Bit 1 (PG)
3    PD2    DAC Pixel Data Bit 2 (PR)
4    PD3    DAC Pixel Data Bit 3 (PI)
5    PD4    DAC Pixel Data Bit 4 (SB)
6    PD5    DAC Pixel Data Bit 5 (SG)
7    PD6    DAC Pixel Data Bit 6 (SR)
8    PD7    DAC Pixel Data Bit 7 (SI)
9    CLK    DAC Clock
10   BLK    DAC Blanking
11   HSYNC    Horizontal Sync
12   VSYNC    Vertical Sync
13   GND    Ground
14   GND    Ground
15   GND    Ground
16   GND    Ground
17        Select Internal Video
18        Select Internal Sync
19        Select Internal Dot Clock
20   n/c    Not used
21   GND    Ground
22   GND    Ground
23   GND    Ground
24   GND    Ground
25   n/c    Not used
26   n/c    Not used
It has the 8 data pins I'm looking for and a clock pin, but I don't think I can use the hsync/vsync... I'd need a FRM source, tho.
Users browsing this forum: No registered users and 154 guests
