It is currently Tue Aug 18, 2026 5:37
PostPosted: Wed Mar 29, 2006 14:29
Is it possible to connect those 640x480 Planar EL-displays to the SED-controller to get the display even partially working?
I could get few cheap panels but if they can't be used in any way...
PostPosted: Wed Mar 29, 2006 21:11
Give Coorz or One~Zero a poke they will tell you for sure , but i am pretty sure the size limit is 640x240
So no you cant wire them to a sed , you need something better...... :D
Sorry dude
PostPosted: Wed Mar 29, 2006 22:52
Depending of the exact display model SED1335 might be possible to interface , at least using some interface logic. But I wouldn't go that way.
Do you know the model numbers ? Depending of the type I might be able to offer some solution for you.
PostPosted: Wed Mar 29, 2006 23:20
EL640.480-AD4
PostPosted: Sun Apr 02, 2006 12:00
hi
I have got the same problem! I have got an old laptop display without controller, I know the pin identifications, and a good IC (the datasheet of the segment drivers suggest it) MSM6255, but I dont know where can I buy ?, and a I dont know WHY is ADRESS INPUT pins (A0-A15) (expect A0 i Think this is the command / data pin) (there is no Enable pin, but there is WRite and Read pin)
thanks
PostPosted: Fri Apr 07, 2006 3:18
Zee wrote:
EL640.480-AD4
I was really trying to get at least 2 of these, but got outbid on the last 4 I've bid on :evil:
I was really wanting to play with this one for sure!!!
If you can still get them, how much??? PM me if you want :wink:
Users browsing this forum: No registered users and 85 guests
