| 2xhd61202fs problem http://forum.lcdinfo.com/viewtopic.php?f=6&t=1649 |
Page 1 of 2 |
| Author: | srck [ Tue Aug 08, 2006 19:18 ] |
| Post subject: | 2xhd61202fs problem |
hello i have lcd pcb-lcm087. it has 2 drivers hd61202fs and 20pins. can i use this schemat for connect http://www.skippari.net/lcd/ks0108.html ? it will be workin? maybe sb has other schemats ? please help. thanks |
| Author: | srck [ Fri Aug 11, 2006 9:59 ] |
between hd61202fs is hd61203fs. who knows how can i connect it? |
| Author: | coorz [ Fri Aug 11, 2006 10:30 ] |
hd61202 is not a LCD controller but a column driver. Your display has no LCD controller and cannot be hooked up to LPT. |
| Author: | Michael [ Fri Aug 11, 2006 11:36 ] |
The hd61203 is the controller and is fully compatible with the KS0108/7 and the link your provided should be fine, has done for me with my hk61202/3's Some recent ks0108's i've picked up have had only one chip select line with the logic level deciding which column driver is selected. |
| Author: | coorz [ Fri Aug 11, 2006 11:59 ] |
| Author: | srck [ Sat Aug 12, 2006 23:38 ] |
i connected this lcd with schemat of ks0108 but lcd doesn't work. mayby schemat is wrong? When i'm only connecting to lpt should lcd working? which programms can i use? The lcd_ks0108_test doesn't work on my pc "cannot find VCL50.BPL. Somebody knows whats wrong? and if sb wants fotos of this lcd please give email. |
| Author: | Michael [ Sun Aug 13, 2006 1:56 ] |
http://www.hac4.com/downloads/vcl50.zip |
| Author: | srck [ Sun Aug 13, 2006 12:10 ] |
and lcd still doesn't work. maybe it needs other schematic? |
| Author: | Michael [ Thu Aug 17, 2006 14:50 ] |
Find the HD61202/3 datasheet then verify you've connected the signals (pins) accordingly. |
| Author: | srck [ Fri Aug 18, 2006 1:14 ] |
datasheet of hd61203 cant help me. maybe somebody can write to this seller http://cgi.ebay.com/GRAPHICS-LCD-MODULE ... dZViewItem because this lcd is like mine. This seller has a schematic. Maybe he will give it. Please help me. |
| Author: | srck [ Sun Aug 27, 2006 17:44 ] |
please help me;( |
| Author: | Michael [ Sun Aug 27, 2006 18:08 ] |
Try posting a few detailed photos of each side. |
| Author: | srck [ Sun Aug 27, 2006 21:05 ] |
| Author: | Michael [ Mon Aug 28, 2006 0:04 ] |
Is this your LCD? http://homepage.oniduo.pt/aduro/LCM087.pdf (128x48) |
| Author: | srck [ Mon Aug 28, 2006 0:18 ] |
i thing it is;) |
