It is currently Mon Nov 23, 2026 15:57
PostPosted: Sun Sep 17, 2006 23:24
Hi all,
I'm going to wire a lcd with a KS0108 controller using the diagram from this site. Here it is:
But I have questions about the power supply.
1) Why dont we use the power from the parallel port ?
2) Why are pin 18 to 25 from the parallel port connected to the ground ?
3) Are pin 18 to 25 connected to the ground of the parallel port or to the ground of the power supply ? Or does it not mather ?
Thanks for answering my questions.
PostPosted: Mon Sep 18, 2006 22:25
1) LPT probably doesn't supply enough power (current) to drive an LCD
2) Uhm because they are GROUND pins :D
3) connect them to the same GROUND of the powersupply that powers your LCD.
Please make sure of wiring the GROUNDS properly, KS0108 is very picky...
Users browsing this forum: Bing [Bot] and 7 guests
