| Oddball Optrex LCD http://forum.lcdinfo.com/viewtopic.php?f=6&t=1737 |
| Author: | AceVonWildfire [ Tue Sep 26, 2006 18:07 ] |
| Post subject: | Oddball Optrex LCD |
Hey ya'll... I've been working with LCDs for just under a month now. I have a powertip PC2402A (2x24) LCD rigged to my server... superglued to a 3.5 to 5.25 drive bay adapter. It looks really cool with that green backlight coming of a black case in the dark. I also have 7 other displays, some with a backlight and some without, that I'm working on hooking up. The one I'm currently working on appears to be a 240x64 graphical display module from Optrex. It's marked thus: MDK311V-0 (Bottom right) Optrex Japan (Top right) PWB633A-V0 and... stamped near the connection pins is: DMF633N-CY (not 100% sure that's a "C" but it's the closest I can get) The board has 7 "HD" chips... 6 that are the same and 1 that is something else. HD61100A (x6) HD61103A (x1) This board also has a very small IC in the top left near the connection pins labeled: C324G 9646QM13 What really struck me as odd on this display is that it only has 10 connection pins instead of the typical 14/16 (20 for some). There is a separate back light connection for it... and it works perfectally at 5V. I would appreciate any help... as google turns up next to nothing on this board. Thanks Ace Von Wildfire |
| Author: | Michael [ Tue Sep 26, 2006 19:38 ] |
Your display seems as if it's controllerless as the HD61100 and HD61103 are the column and row drivers. A controller for these would be the HD61380. |
| Author: | AceVonWildfire [ Tue Sep 26, 2006 21:54 ] |
Well crap. Was hoping it'd be simple to rig up. Oh well... time to start looking for a controller. Thanks. Ace Von Wildfire |
| Author: | AceVonWildfire [ Thu Sep 28, 2006 18:26 ] |
Does anyone have a datasheet or, at the very least, a pinout for this LCD? I have been less than successfull with the google searches. And Optrex seems to refuse to reply to any messages I send to them. I would appreciate any help. Thanks Ace Von Wildfire |
| Author: | One~Zero [ Sat Sep 30, 2006 11:11 ] |
It indeed uses the HD61830 controller, which has since been replaced by the LC7981 controller. The spec sheet for your display is here: DMF633 This is a 2 bit display, which is why you see less output pins for connections. |
| Author: | AceVonWildfire [ Mon Oct 02, 2006 15:43 ] |
Quote: It indeed uses the HD61830 controller, which has since been replaced by the LC7981 controller. Hmmm... any idea where I can get either chip for a decent price? Quote: The spec sheet for your display is here: Cool... Thanks. Quote: This is a 2 bit display, which is why you see less output pins for connections.
Hrumph... is this display even worth hooking up, then? Ace Von Wildfire |
| Author: | One~Zero [ Mon Oct 02, 2006 15:50 ] |
The chip itself won't do you any good, as you would need to build the whole controller for it. It's not that hard to do and I can sell you the LC7981 IC if you want. I've built a couple of these controllers before, but don't currently have any already built. It's definitely worth hooking up. It just handles the 8 bit input data a little differently than a 4 bit display. Still works fine though. |
