| Probs with Crystalfontz 128x64 KS0108 display http://forum.lcdinfo.com/viewtopic.php?f=6&t=178 |
| Author: | Rembooo [ Wed Mar 19, 2003 12:41 ] |
| Post subject: | Probs with Crystalfontz 128x64 KS0108 display |
I used the search and couldn't find any topic about this problem, so i'll post it here. I wired my LCD (CFAG12864B-TMI-V) up and connected it, but all it showed was this: So i resoldered it completely, and got the same problem. It also shows that screen when i only plug the power in. Now i'm sitting here with an LCD with only the +5, GND, Vcontrast & Vee connected, and it still gives the same screen. Is it normal for an LCD to give this screen when it isn't connected or is my LCD broken? I certainly don't hope so |
| Author: | Henri [ Wed Mar 19, 2003 16:13 ] |
| Post subject: | Re: Probs with Crystalfontz 128x64 KS0108 display |
Usually results like this are seen when there is some problem with the wiring and timing. But as your display isn't even connected this shouldn't be the problem. When I switch my display on it just stays blank and only shows things when driven by some program so I don't think what you see is normal. I've had pictures that resemble your's when I've written data with wrong timing. If no other problem can be spotted I think your display might be defective. |
