It is currently Wed Oct 28, 2026 6:01
 Post subject: KS 0108B+1 ?
PostPosted: Wed Mar 26, 2003 9:34
Can I use LcdInfo with a lcd with KS 0108B+1 controller?
PostPosted: Wed Mar 26, 2003 13:49
I think so. It should be the same as KS0108.
PostPosted: Wed Mar 26, 2003 14:27
hi.
Ok, thx, i go to buy 3 lcds.
what about the connection diagram?
PostPosted: Wed Mar 26, 2003 15:08
Oh, one thing I forgot to say: LCDInfo supports only 128x64 KS0108 displays now.
Details of the connection depend of the specific display but the idea is same for all of them.
PostPosted: Wed Mar 26, 2003 16:21
so i can use the connection diagram from a T6963C Display?!
i dont understand what u mean (im from germany^^)
and yes, its a 128x64 display
PostPosted: Wed Mar 26, 2003 17:09
Connection diagram made for T6963C display won't work but connection diagrams for KS0108 displays should be pretty close to correct. But you probably need to make some changes to the existing diagrams. Like pins may be in different place, different voltages needed and so on...
Datasheet would really help to know how your display needs to be connected.
PostPosted: Fri Mar 28, 2003 17:14
hi
i want to use this:
PostPosted: Sun Mar 30, 2003 1:26
You can probably use something like that but without more information about your display I can say anything. Do you have a datasheet for your display ?
