It is currently Sun Nov 01, 2026 21:58
 Post subject: LCD to display waveforms
PostPosted: Fri Apr 04, 2003 22:30
Hello, I have to design a logic probe with an LCD using 8051 micro. The probe is to indicate the logic levels of 0-15v and also show frequency of the waveforms and display of the waveforms measured. I have trouble finding a graphic LCD and I would like to ask if you have anything to suggest. I need something simple to program and connect to the rest of system and not too expensive.
Hope this ain't much too ask. Thanks in advance.
PostPosted: Sat Apr 05, 2003 21:24
I presume you are looking for displays in Finland ? I think T6963C should be rather simple controller to program. Have you thought of what size display you would need ?
Here's a place in Finland where you can get graphics lcds:
http://www.saunalahti.fi/~pri/lcd.htm
Price for 128x64 display is 58e and for 240x128 140e.
I have one unused 240x128 T6963C display with negative voltage circuit and temperature compensation. I think the price would be <100e. The display has LED backlight. Email me if you are interested.
 Post subject: leijona
PostPosted: Mon Apr 07, 2003 21:15
I just want a 128*64 display
PostPosted: Mon Apr 07, 2003 22:19
Ah, so you're not from Finland. You got me fooled with your nick ;)
Unfortunately I don't know where to get displays outside Finland. Maybe you could check farnell and other distributors.
PostPosted: Tue Apr 08, 2003 15:27
Try digi-key http://www.digi-key.com/
They have all most everything + huge catalog :D
 Post subject: 128x64 display
PostPosted: Tue Jan 18, 2005 6:24
I saw 128x64 displays with RS232 controller at http://www.tvielectronics.com.
