It is currently Fri Oct 30, 2026 15:56
PostPosted: Sun Apr 20, 2003 13:06
I Have 2 Hitachi LMG6912RPFC Displays with HD64645 Controller how can i connect it to my PC, and will it work with LCDinfo ?
 Post subject: Facts
PostPosted: Sun Apr 20, 2003 13:21
Sorry!
Here you can get some Facts about:
http://www.vtc.edu/courses/el/el314/arc ... b001d1.pdf
http://www.inside-usa.com/support/faqs/ ... 0009-A.htm
PostPosted: Mon Apr 21, 2003 12:30
LCDInfo doesn't support this display. How big is it ? If it's 640x480 or something like that it probably needs a controller to use it for anything.
PostPosted: Mon Apr 21, 2003 13:12
Hi the Display Size is 320x240 and the Controller are HD64645 for this Display but i dont know how to connect it to the PC-Parallelport. I have a completely function Controlling Unit from an old Aplicom Fleet Managment System it includes the Memory and the Controller for the Display.
my question is is it possible to use it with LCDinfo or MP3Liquid or any other Software. I've also the Pinout of the Controlling Unit and will try to connect it in this Week. If it works I post it in the Forum. :)
PostPosted: Wed Apr 23, 2003 21:09
When I looked at the information you provided I got the feeling that the display would need some external controller. I'm not sure though.
In any case it will require some coding to make it work in parallel port.
