It is currently Wed Nov 11, 2026 9:15
PostPosted: Wed Feb 07, 2007 2:16
Hello. I am new when it comes to the concept of using an LCD screen from a laptop without the actual laptop. I have a Samsung LT141X4. I know that I am going to need a controller to use the monitor with either vga or composite inputs, but I am having a great deal of trouble finding one. If anyone could be of assistance It would be greatly appreciated. I have found this this but I am not sure if it will work in the manor that I need (it list my lcd model in the chart).
Just to clarify what I am going to be using the LCD for, I need to be able to use it like a television with a composite video in.
Thank you once again, and any help is appriciated
PostPosted: Sat Feb 10, 2007 2:33
If the controller lists your panel in the compatibility list and also ships with fitting cable with correct connectors it should work with your display.
And looks like the controller supports composite input so it should work for you.
PostPosted: Mon Feb 12, 2007 3:41
thank you very muchs
Users browsing this forum: Google [Bot] and 287 guests
