It is currently Tue Nov 10, 2026 7:52
PostPosted: Sat Feb 03, 2007 14:07
Hello everyone!
I need some help to understand the wiring for Lcd 320*240 to Parallel Port, the specifications are:
PCB Size: 160 x 109 mm
Body Size: 167 x 109 mm
Viewing Area: 124 x 94 mm
Dot Size: 0.34 x 0.34 mm
Pitch Size: 0.36 x 0.36 mm
LCD Type: STN, Blue-White, Negtive
Veiwing Direction: 6:00 o'clock
Power: Single 3 ~ 5V operation, 30 ~ 40mA(Typical).
Backlight: CCFL 5V <500mA(Typical), CCFL DC/AC adaptor included for the item.
Built-in Controller IC: SED1335 or S1D13305 or Equivalent, SMT.
PINNING:
1. Vss
2. Vdd
3. V0
4. /WR
5. /RD
6. /CS
7. A0
8. /RST
9-16. DB0 - DB7
17. NC
18. Vee
19. NC
20. NC
datasheet: http://www.qingyun-it.com/products/yeji ... 202401.pdf
I think thant the inverter is included with the lcd..
i dont have any schematic for this controller to connect it to the printer port!
can you help me?
PostPosted: Sat Feb 10, 2007 2:31
Some examples of SED1335 schematics are here: http://forum.lcdinfo.com/viewtopic.php?t=549
You may not find the exact match but based on the existing schematics you should be able to combine the pin names the same way and form your own schematic this way.
