| Unidentificable LCD! http://forum.lcdinfo.com/viewtopic.php?f=6&t=2173 |
| Author: | santiago [ Fri Mar 23, 2007 3:00 ] |
| Post subject: | Unidentificable LCD! |
Hi! I'm new in this forum. I'd like to kow if someone could help me to identify a LCD. It has 3 pc-pu34f as horizontal drivers, 4 pc-pu33c as vertical drivers and in the back side of the PCB there is a number: gcmk-g2x. Also there is a 14 pin ribbon connector. I believe that the LCD has a resolution of 320x240. I´ve tried to find it's datasheet but there is nothing on the Internet. I would be glad to receive any kind of information about the LCD. If it helps, in the back side of the screen is the serial number: FH6-0604. Thanks. |
| Author: | bullfrog [ Mon May 21, 2007 10:50 ] |
I too have one of these and am interested in trying to connect it, as far as I can figure if you use a SED controller and connect it up using the diagram listed in the forum it should work?? HAVE YOU HAD ANY LUCK?? |
| Author: | santiago [ Thu Jun 14, 2007 5:04 ] |
One of mi friend tried to make it work but he had no results. After that, we didn't tried any more as we couldn't find precise information about the display. Good luck with your proyect! |
