It is currently Fri Apr 26, 2024 14:54
 Post subject: Nokia 3510i lcd
PostPosted: Sat Mar 24, 2007 2:19
Hi, i'm looking to use an lcd from a nokia 3510i, so far i've found out the following information:
Model: Epson S1D15G14
Supply Voltage: 2.35 to 3.6V
Color Mode: color
Driver Type: passive
Output: 82/104 x RGB
LCD Voltage: 16.0 to 25.0V
LCD power supply circuit: external, internal
Duty: 1/82,1/65
Display RAM (bits): 312x82x4
CPU Interface: serial,parallel
Packages: au bump chip
Temperature Range: -40 to +85°C
Features: MLS
Status: MP
I'm new to all of this so simple instructions would be useful. I'm just looking for some information on using this screen.
Is it possible to use a colour screen? I know I've seen someone using one before.
EDIT: There are 8 pins on the lcd. This website has a data sheet: http://www.mikrocontroller.net/attachment/2528/D15G14E_14_030526.pdf
 Post subject: Try Google
PostPosted: Sun Mar 25, 2007 17:34
Hello, here is an example:
http://www.geocities.com/neil_manc/pic16f84/index.htm
You can find more info by searching "3510i lcd interfacing" at Google.
Hope this helps.
Cex.
Users browsing this forum: No registered users and 51 guests
