| Nokia 3510i lcd http://forum.lcdinfo.com/viewtopic.php?f=6&t=2176 |
| Author: | jakeblat [ Sat Mar 24, 2007 2:19 ] |
| Post subject: | Nokia 3510i lcd |
Hi, i'm looking to use an lcd from a nokia 3510i, so far i've found out the following information: Model: Epson S1D15G14 Supply Voltage: 2.35 to 3.6V Color Mode: color Driver Type: passive Output: 82/104 x RGB LCD Voltage: 16.0 to 25.0V LCD power supply circuit: external, internal Duty: 1/82,1/65 Display RAM (bits): 312x82x4 CPU Interface: serial,parallel Packages: au bump chip Temperature Range: -40 to +85°C Features: MLS Status: MP I'm new to all of this so simple instructions would be useful. I'm just looking for some information on using this screen. Is it possible to use a colour screen? I know I've seen someone using one before. EDIT: There are 8 pins on the lcd. This website has a data sheet: http://www.mikrocontroller.net/attachment/2528/D15G14E_14_030526.pdf |
| Author: | cex [ Sun Mar 25, 2007 17:34 ] |
| Post subject: | Try Google |
Hello, here is an example: http://www.geocities.com/neil_manc/pic16f84/index.htm You can find more info by searching "3510i lcd interfacing" at Google. Hope this helps. Cex. |
