It is currently Fri Oct 09, 2026 8:53
 Post subject: some nokia lcd...
PostPosted: Mon Apr 09, 2007 14:05
Hello. I got this lcd, from used cellar phone...
I measured voltages on cellar phone.
pin1 - CS 1.8V
pin2 - SCK 1.8V
pin3 - SDATA ~V??
pin4 - RESET
pin5 - VCC-DIGITAL 1.8V
other side:
pin1 - LED V+ 6.6V(to pin2) or 7.13V(to pin3) (when leds off) and 18.81V when leds are supposed to be turned on (actually when I turn on the cell phone)
pin2 - GND for LED 0.8V
pin3 - GND 0V
pin4 - /
pin5 - VCC-display 2.75V
Now I would like to attach this lcd to PIC18F and I need to know how to communicate with lcd. Does anyone have PIC16 or PIC18 assembly code for this LCD. I'd like to know LCD commands and stuff. thanks.
 Post subject: Nokia 6100
PostPosted: Tue Apr 10, 2007 11:25
Hello,
your LCD looks like a 6100 LCD with Epson controller.
You can find code for PIC and AVR to drive that display over the net (try "6100 lcd library" or ""6100 lcd driver" at google).
Hope this helps.
Cex.
This is what I used to test my Nokia color LCDs with 16F627...
W                            EQU     H'0000'
F                            EQU     H'0001'
CMD            EQU   H'0000'
DAT            EQU   H'0001'
;----- Register Files------------------------------------------------------
INDF                         EQU     H'0000'
TMR0                         EQU     H'0001'
PCL                          EQU     H'0002'
STATUS                       EQU     H'0003'
FSR                          EQU     H'0004'
PORTA                        EQU     H'0005'
PORTB                        EQU     H'0006'
INTCON                       EQU     H'000B'
OPTION_REG                   EQU     H'0081'
TRISA                        EQU     H'0085'
TRISB                        EQU     H'0086'
CMCON                        EQU     H'001F'
;----- STATUS Bits --------------------------------------------------------
IRP                          EQU     H'0007'
RP1                          EQU     H'0006'
RP0                          EQU     H'0005'
NOT_TO                       EQU     H'0004'
NOT_PD                       EQU     H'0003'
Z                            EQU     H'0002'
DC                           EQU     H'0001'
C                            EQU     H'0000'
;       RAM Definition
    __MAXRAM H'01FF'
    __BADRAM H'07'-H'09', H'0D', H'13'-H'14', H'1B'-H'1E'
    __BADRAM H'87'-H'89', H'8D', H'8F'-H'91', H'93'-H'97', H'9E'
    __BADRAM H'105', H'107'-H'109', H'10C'-H'11F', H'150'-H'16F'
    __BADRAM H'185', H'187'-H'189', H'18C'-H'1EF'
;       Configuration Bits
_BODEN_ON                    EQU     H'3FFF'
_BODEN_OFF                   EQU     H'3FBF'
_CP_ALL                      EQU     H'03FF'
_CP_75                       EQU     H'17FF'
_CP_50                       EQU     H'2BFF'
_CP_OFF                      EQU     H'3FFF'
_DATA_CP_ON                  EQU     H'3EFF'
_DATA_CP_OFF                 EQU     H'3FFF'
_PWRTE_OFF                   EQU     H'3FFF'
_PWRTE_ON                    EQU     H'3FF7'
_WDT_ON                      EQU     H'3FFF'
_WDT_OFF                     EQU     H'3FFB'
_LVP_ON                      EQU     H'3FFF'
_LVP_OFF                     EQU     H'3F7F'
_MCLRE_ON                    EQU     H'3FFF'
_MCLRE_OFF                   EQU     H'3FDF'
_ER_OSC_CLKOUT               EQU     H'3FFF'
_ER_OSC_NOCLKOUT             EQU     H'3FFE'
_INTRC_OSC_CLKOUT            EQU     H'3FFD'
_INTRC_OSC_NOCLKOUT          EQU     H'3FFC'
_EXTCLK_OSC                  EQU     H'3FEF'
_LP_OSC                      EQU     H'3FEC'
_XT_OSC                      EQU     H'3FED'
_HS_OSC                      EQU     H'3FEE'
   __CONFIG        _BODEN_ON & _CP_OFF & _DATA_CP_OFF & _PWRTE_ON & _WDT_OFF & _LVP_OFF & _MCLRE_ON & _HS_OSC
TIMER1      EQU   H'20'
TIMER2      EQU   H'21'
BYTE      EQU   H'22'
COUNT1      EQU   H'23'
COUNT2      EQU   H'24'
BYTE2      EQU   H'25'
      ORG   0
      GOTO   RESET
DELAY      MOVLW   D'54'
      MOVWF   TIMER2
DEL_LOOP1   MOVLW   D'60'
      MOVWF   TIMER1
DEL_LOOP2   DECFSZ   TIMER1,F
      GOTO   DEL_LOOP2
      DECFSZ   TIMER2,F
      GOTO   DEL_LOOP1
      RETURN
DELAY2;      MOVLW   D'1'
;      MOVWF   TIMER2
DEL_LOOP3   MOVLW   D'1'
      MOVWF   TIMER1
DEL_LOOP4   DECFSZ   TIMER1,F
      GOTO   DEL_LOOP4
;      DECFSZ   TIMER2,F
;      GOTO   DEL_LOOP3
      RETURN
LCD_WRITE   MOVWF   PORTB
      MOVLW   B'00000001'
      MOVWF   PORTA
;      CALL   DELAY2
      MOVLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
      RLF   BYTE,F
      MOVF   BYTE,W
      ANDLW   H'01'
      MOVWF   PORTB
      IORLW   H'02'
      MOVWF   PORTB
;      CALL   DELAY2
      MOVLW   B'00000011'
      MOVWF   PORTA
      RETURN
;              **  RESET :  main boot routine  **
RESET      MOVLW   B'00000111'   ;Disable Comparator module's
      MOVWF   CMCON
      BSF   STATUS,RP0   ;Switch to register bank 1
               ;Disable pull-ups
               ;INT on rising edge
               ;TMR0 to CLKOUT
               ;TMR0 Incr low2high trans.
               ;Prescaler assign to Timer0
               ;Prescaler rate is 1:256
      MOVLW   B'11010111'   ;Set PIC options (See datasheet).
      MOVWF   OPTION_REG   ;Write the OPTION register.
      CLRF   INTCON      ;Disable interrupts
      MOVLW   B'11000000'
      MOVWF   TRISB      ;RB7 & RB6 are inputs.
               ;RB5...RB0 are outputs.
      MOVLW   B'11111100'   ;all RA ports are inputs
      MOVWF   TRISA
      BCF   STATUS,RP0   ;Switch Back to reg. Bank 0
      CLRF   PORTB
      MOVLW   B'00000010'
      MOVWF   PORTA
;      CALL   DELAY
      MOVLW   H'FF'
      MOVWF   PORTB
;      CALL   DELAY
      MOVLW   H'00'
      MOVWF   PORTB
;      CALL   DELAY
      MOVLW   B'00000011'
      MOVWF   PORTA
;      CALL   DELAY
      MOVLW   H'00'
      MOVWF   BYTE2
;      GOTO   PHILIPS
      MOVLW   H'BB'      ;COMSCN
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'01'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'D1'      ;OSCON
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'94'      ;SLPOUT
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'20'      ;PWRCTR
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'0F'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'A7'      ;DISINV
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'BC'      ;DATCTL
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'03'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'01'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'CE'      ;RGBSET8
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      GOTO   RGB
PHILIPS      MOVLW   H'38'      ;IDMOFF
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'11'      ;SLPOUT
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'3A'      ;COLMOD
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'02'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'25'      ;SETCON
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'3E'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'23'      ;DAL
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'36'      ;MADCTL
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'88'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'2D'      ;RGBSET8
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
RGB      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'02'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'04'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'06'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'08'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0A'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0C'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0E'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'02'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'04'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'06'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'08'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0A'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0C'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0E'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'04'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'08'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'0C'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
;      MOVLW   H'13'      ;NORON   (Philips)
;      MOVWF   BYTE
;      MOVLW   CMD
;      CALL   LCD_WRITE
      MOVLW   H'AF'      ;DISON   (Epson)
;      MOVLW   H'29'      ;DISON   (Philips)
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'75'      ;PASET   (Epson)
;      MOVLW   H'2B'      ;PASET   (Philips)
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'83'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'15'      ;CASET   (Epson)
;      MOVLW   H'2A'      ;CASET   (Philips)
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
      MOVLW   H'00'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
      MOVLW   H'83'
      MOVWF   BYTE
      MOVLW   DAT
      CALL   LCD_WRITE
REPEAT
      MOVLW   H'5C'      ;RAMWR   (Epson)
;      MOVLW   H'2C'      ;RAMWR   (Philips)
      MOVWF   BYTE
      MOVLW   CMD
      CALL   LCD_WRITE
;      MOVLW   H'00'
      MOVF   BYTE2,W
      COMF   BYTE2,F
      MOVWF   BYTE
      MOVLW   D'132'
      MOVWF   COUNT2
FILL_LOOP1   MOVLW   D'132'
      MOVWF   COUNT1
FILL_LOOP2   MOVLW   DAT
      CALL   LCD_WRITE
;      INCF   BYTE,F
      DECFSZ   COUNT1,F
      GOTO   FILL_LOOP2
;      INCF   BYTE,F
      DECFSZ   COUNT2,F
      GOTO   FILL_LOOP1
;      MOVLW   H'00'
;      MOVWF   PORTB
THE_END      GOTO   REPEAT
      END
PostPosted: Tue Apr 10, 2007 11:54
thanks zee. I hope this works :D
PostPosted: Tue Apr 10, 2007 12:10
I've found this:
I've modified it a bit from different parts, so it's not a real code.
#define DISON      0xaf   //
#define DISOFF      0xae   //
#define DISNOR      0xa6   //
#define DISINV      0xa7   //
#define COMSCN      0xbb   //
#define DISCTL      0xca   //
#define SLPIN      0x95   //
#define SLPOUT      0x94   //
#define PASET      0x75   //
#define CASET      0x15   //
#define DATCTL      0xbc   //
#define RGBSET8      0xce   //
#define RAMWR      0x5c   //
#define RAMRD      0x5d   //
#define PTLIN      0xa8   //
#define PTLOUT      0xa9   //
#define RMWIN      0xe0   //
#define RMWOUT      0xee   //
#define ASCSET      0xaa   //
#define SCSTART      0xab   //
#define OSCON      0xd1   //
#define OSCOFF      0xd2   //
#define PWRCTR      0x20   //
#define VOLCTR      0x81   //
#define VOLUP      0xd6   //
#define VOLDOWN      0xd7   //
#define TMPGRD      0x82   //
#define EPCTIN      0xcd   //
#define EPCOUT      0xcc   //
#define EPMWR      0xfc   //
#define EPMRD      0xfd   //
#define EPSRRD1      0x7c   //
#define EPSRRD2      0x7d   //
#define NOP      0x25   //
WriteCommand(COMSCN);
WriteData(0x01);
WriteCommand(OSCON);
WriteCommand(SLPOUT);
WriteCommand(PWRCTR);
WriteData(0x0f);
WriteCommand(DISINV);
WriteCommand(DATCTL);
WriteData(0x03);
WriteData(0x00);
WriteData(0x01);
WriteCommand(RGBSET8);
WriteData(0x00);   // R
WriteData(0x02);   // R
WriteData(0x04);   // R
WriteData(0x06);   // R
WriteData(0x08);   // R
WriteData(0x0a);   // R
WriteData(0x0c);   // R
WriteData(0x0e);   // R
WriteData(0x00);   // G
WriteData(0x02);   // G
WriteData(0x04);   // G
WriteData(0x06);   // G
WriteData(0x08);   // G
WriteData(0x0a);   // G
WriteData(0x0c);   // G
WriteData(0x0e);   // G
WriteData(0x00);   // B
WriteData(0x04);   // B
WriteData(0x08);   // B
WriteData(0x0c);   // B
Delay(100000);
WriteCommand(DISON);
; ports and pins for display interface
#define NRESET   PORTB, 0
#define NCS   PORTB, 1
#define SCK   PORTB, 3
#define SDA   PORTB, 2
_s_byte   EQU   B0h      ; lcd send byte
; exported function: LC3510_SET_12BPP: pixels are packed RRRRGGGGBBBB
; no parameters
LCD3510_SET_12BPP
   movlw   0x3A
   call   _command
   movlw   0x03
   call   _parameter
   return
; exported function: LC3510_SET_8BPP. pixels are packed RRRGGGBB
; no parameters
LCD3510_SET_8BPP
   movlw   0x3A
   call   _command
   movlw   0x02
   call   _parameter
   return
_command
   movwf   _s_byte         ; save W reg
               ; terminate any prior sequence of parameters
   bsf      NCS
   bcf      SCK
   bcf      NCS
               ; first bit is zero for command
   bcf      SDA
   bsf      SCK
   bsf      SDA      ; data pin high, ready for byte sending
   goto   __send_byte
_parameter
   bcf      SCK      ; clock in a one for parameter
   bsf      SDA
   bsf      SCK
__send_byte            ; Send 8 bits = 1 byte
   bcf      SCK
   btfss   _s_byte, 7   ; if ( bit7=1 ){ SDA=0; } else { SDA=1; }
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 6   ; če je bit6 1, potem SDA=1, če je bit6 0, potem SDA=0
   bsf      SDA
   btfss   _s_byte, 6
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 5
   bsf      SDA
   btfss   _s_byte, 5
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 4
   bsf      SDA
   btfss   _s_byte, 4
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 3
   bsf      SDA
   btfss   _s_byte, 3
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 2
   bsf      SDA
   btfss   _s_byte, 2
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 1
   bsf      SDA
   btfss   _s_byte, 1
   bcf      SDA
   bsf      SCK
   bcf      SCK
   btfsc   _s_byte, 0
   bsf      SDA
   btfss   _s_byte, 0
   bcf      SDA
   bsf      SCK
   return
Users browsing this forum: No registered users and 212 guests
