| lcd screens need help wiring + software http://forum.lcdinfo.com/viewtopic.php?f=6&t=2211 |
| Author: | Henri [ Wed Apr 25, 2007 12:22 ] |
Looking at this picture http://img225.imageshack.us/my.php?imag ... 008tw3.jpg the large square QFP chip is a TMP87C841U microcontroller. So it has a custom program in it that we don't know what it does. And the 30 pin connector and it's communication protocol isn't documented anywhere. And on top of that looks like the board has got quite rough handling so it probably would need fixing before it works. But that looks like a 320x240 pixel Sharp LCD panel and it has 12 pins. It might work with the S1D13305 controller board with 12 pin FFC connector from here: http://www.skippari.net/forsale/ S1D13305 controller is also supported in the PC softwares that you would probably like to use. This is the pinout that the controller has
You could try measuring with a multimeter where the pins from the 12 pin connector on your board go and compare to the above pinout. First I'd check the power pins like VDD and GND and if those match then continue trying to figure out the rest. If the power pins match I think there's a pretty good chance the rest is in the same order too. |
| Author: | Henri [ Wed Apr 25, 2007 12:44 ] |
The 4 pin connector is for a touch screen. But I don't have any touch solution to point you to at the moment. There are some separate touch screen controller boards but I'm not sure how you would take advantage of them at this time unless you plan to write your own software. This is most likely a monochrome lcd. Ok, I'm 99% sure of that. |
| Author: | paul [ Wed Apr 25, 2007 12:52 ] |
I don't need the touch screen feature all that much i was just going to use it to get stats like temp, time, date and scrolling text. ok thanks for all your help i will try to get this lcd connected asap and will post back when i do. edit: ps i have two of these screens but one is covered in mud and i don't think it will work. |
| Author: | paul [ Thu Apr 26, 2007 12:00 ] |
Hey i was wondering how i would go about hooking the lcd controller board to my pc, printer port? most of these screens i have read about are connected through the printer port. |
| Author: | Henri [ Thu Apr 26, 2007 14:12 ] |
Even if you don't use the touchscreen you might think of it as a plus, as if you want, you could remove the touchscreen glass and under it you should find an untouched lcd glass without any scratches or other marks that can be often seen in used displays. Yes this controller would be connected to printer port. That is the way the common software supports connecting these controllers.
Not very complicated wiring as all the "difficult" stuff is handled on the controller board. |
| Author: | paul [ Thu Apr 26, 2007 14:15 ] |
great diagram thanks for the help, what sort of software would i be using to control it any you would suggest? |
| Author: | Henri [ Thu Apr 26, 2007 14:26 ] |
Some that you could check are LCDInfo, LCDStudio, LCDHype There are some others too but these were the first I thougth of. |
| Author: | paul [ Thu Apr 26, 2007 14:31 ] |
ok sorry about this but last one, would i find the S1D13305 LCD controller in an epson stylus photo 935 model number b151b, i just remembered that i have an old one that has a black n white screen with another little 2.5 inch color screen. thanks for the software |
| Author: | Henri [ Thu Apr 26, 2007 14:36 ] |
Epson Stylus Photo 935 is a printer I see. I highly doubt you would find a controller like S1D13305 or similar in a product like this. Most likely it has something highly integrated custom circuitry inside without any documentation available. |
| Author: | paul [ Thu Apr 26, 2007 14:43 ] |
ok thank you just have to wait till i make some money to buy the lcd controller, thanks for your help i will post back when i get it hooked up or need help, thanks heaps! |
| Author: | raduvadim [ Sun Nov 11, 2012 23:22 ] |
| Post subject: | Re: lcd screens need help wiring + software |
Hello, and thank you for creating this wonderful forum. I happen to own a Sharp LM32015t, which is compatible with the pinout of the sharp lm32007 discussed in this topic.I managed to get the voltage pump working, and assembled a led backlight instead of the ccfl one.my problem is that i do not know how to match the following pins: CP1, CP2, S with the control pins from the lpt side: /WR, /RD, /CS, A0. I appreciate any support in solving my problem, as i do not have the money to buy a controller board at this time. Thank you and sorry for my bad english. |
