It is currently Fri Oct 09, 2026 16:36
PostPosted: Mon Apr 30, 2007 15:47
Please help me, I have a P141-18B Datavision Touch screen but can not find a datasheet anywhere I have spent the past 2 weeks looking for one or some one that can help me with no luck has any one here used one of these screens or knows where I can get a datasheet.
Please help
Chris
PostPosted: Tue May 01, 2007 10:21
I have found out that it has the S1D1330F (or SID1330F) IC on it I have a datasheet for the SED1330F are they the same ?? All I need now is the pin outs for the actual screen itself.
PostPosted: Wed May 02, 2007 14:32
If you have the SED1330F datasheet then with the use of a multimeter you can discover the pinouts, t'is pretty easy. You'll be looking for the following pins on the connector from the chip: d0 to d7, RES, RD, WR, CS and A0. Then Gnd/Vss(0v), Vdd (5v) and possibly -Vee (LCD drive, around -20v).
Just this week I did exactly this for the Panasonic W1030 (480x128).
If you don't mind can you post your findings for others for future reference?
http://mylcd.sourceforge.net/
PostPosted: Wed May 02, 2007 14:56
Hi Michael, I have check with multimeter and got pin outs I just like to have the datasheet to hand as well just so I can check voltages etc.
I have followed the example they have in the sed1330 datasheet but nothing working so I just want to check I haven't done anything stupid. the example I followed is on page 123 onwards.
and heres the link to the SED1330
http://www.coe.montana.edu/ee/rlarimer/ ... _Sheet.pdf
PostPosted: Mon May 14, 2007 12:58
Ok, a little more help needed. I have the display setup and displaying letters and numbers but it is repeating everything 4 times down the display. Is this a simple setup that has gone wrong I can supply code if you want.
Has anyone come across this problem before ?
Chris
Users browsing this forum: No registered users and 76 guests
