It is currently Thu Apr 25, 2024 23:07
PostPosted: Fri May 18, 2007 0:06
HI,
I have a graphical lcd but I cant find its datasheet
it is made in china, So all the ICs at the back of this lcd have no Number
there is only one Number written at it: QY-12864BG
is this its serial No or this Number just tells us the resolution is 128*64 pixel????
there are also the pin description which is:
1.. VSS
2.. VDD
3..V0
4..RS
5..R/W
6..E
7:14..d0:d7
15..CS1
16..CS2
17..RST
18..VOUT
19..led+
20..led-
could you tell me what is the function of this pin??
and how to program this lcd using AVR or 8051??
thank you any way....
PostPosted: Fri May 18, 2007 13:07
gameelgamal wrote:
HI,
1.. VSS
2.. VDD
3..V0
4..RS
5..R/W
6..E
7:14..d0:d7
15..CS1
16..CS2
17..RST
18..VOUT
19..led+
20..led-
could you tell me what is the function of these pins??
I have one of these also. It's 128x64 lcd with a KS0108 controller.
http://mylcd.sourceforge.net/
PostPosted: Fri May 18, 2007 20:31
thank you for your help
I have another request, Do you have any example code to run this glcd using AVR or 8051 microcontroller
thank you.....
Users browsing this forum: No registered users and 62 guests
