It is currently Fri Oct 09, 2026 6:45
 Post subject: 128 x 128 Lcd
PostPosted: Fri Jun 22, 2007 10:47
Recently I got a 128 x 128 dot graphic lcd panel from ebay. The LCD and datasheet can be found here: http://maverickelectronic.com/lcds.html
One question I have is that it has 4 Chip select lines, most panels I have seen only have two. Does this require extra logic? Or can it run from two chip select lines?
PostPosted: Fri Jun 22, 2007 11:40
From what I can tell it's the same as a Displaytech 64240A
PostPosted: Fri Jun 22, 2007 21:28
Using only 2 CS line will only allow you to access two of the 4 KS0108 ie any pair of 64x64 pixel groups.
Users browsing this forum: No registered users and 173 guests
