| 128 x 128 Lcd http://forum.lcdinfo.com/viewtopic.php?f=6&t=2261 |
| Author: | davekdublin [ Fri Jun 22, 2007 10:47 ] |
| Post subject: | 128 x 128 Lcd |
Recently I got a 128 x 128 dot graphic lcd panel from ebay. The LCD and datasheet can be found here: http://maverickelectronic.com/lcds.html One question I have is that it has 4 Chip select lines, most panels I have seen only have two. Does this require extra logic? Or can it run from two chip select lines? |
| Author: | davekdublin [ Fri Jun 22, 2007 11:40 ] |
From what I can tell it's the same as a Displaytech 64240A |
| Author: | buze [ Fri Jun 22, 2007 21:28 ] |
Using only 2 CS line will only allow you to access two of the 4 KS0108 ie any pair of 64x64 pixel groups. |
