It is currently Thu Nov 12, 2026 21:14
PostPosted: Fri Dec 14, 2007 11:59
I have a hantronix tft colour graphics display module HDA570V-V which has a 33 pin Kyocera interface.i want to drive it from the VGA port of my ARM9 board running on linux.how do i connect this to my VGA port(15 pins)?do i need to use a converter in between.if yes please give details...any help will be appreciated.
PostPosted: Fri Dec 14, 2007 17:26
The display has a digital interface and 15 pin VGA is analog. Ideally you would want to connect the display to the ARM9 board before the D/A converter for the VGA. Or then you would find some LCD controller board that takes VGA in. The same kind that can be used to connect LCD panels to PC VGA output. But these can be somewhat expensive and it doesn't really feel right to first convert the digital signal to analog and then back to digital when actually no conversions would be needed.
Maybe your ARM9 board would also have a digital display output ?
 Post subject: thanks sir
PostPosted: Wed Dec 19, 2007 10:45
thanks a lot sir....i think you are right....actually the arm9 board at my end doesnt have on chip tft module...may be switching to a processor with on chip tft module will be a better option...by the way can u suggest some controller board manufacturers for interfacing tft module with vga?
http://www.hantronix.com/down/570V-V.pdf
is the link for my lcd which i want to connect with the VGA connector.actually hantronix guys are not offering any support regarding this .so i m stuck as changing the board would be difficult at this stage.i would be grateful if you could offer some help?
thanks and regards
ramandeep singh[/img][/url]
PostPosted: Thu Dec 27, 2007 16:27
Here are just the first results of using a search engine so probably not the best matches:
http://www.spectrah.com/product/index.htm
http://emea.kontron.com/index.php?id=10 ... MAods2n9Ow
If you search a little you should be able to find many other manufacturers.
Is the ARM9 board you're using some custom design or does it have any information available in the internet ? If it isn't a custom design you could post the model and maybe a link to it.
Users browsing this forum: Majestic-12 [Bot] and 22 guests
