It is currently Fri Nov 13, 2026 2:42
PostPosted: Fri Apr 25, 2008 11:49
I have a display LCD but I don't know the pinout and the protocol for comunication. These are the images:
Front: Image
Back: Image
Sorry for the bad images.
Someone can help me?
PostPosted: Sun May 11, 2008 11:32
Hi, I had the same problem but found the info to get it working at this link http://www.mtx-electronics.com/industrial_wireless/e107_plugins/content/content.php?content.6
PostPosted: Sat May 17, 2008 11:52
I try it but don't work. LCDproc give me none negative feedback.
I don't know if the problem is the circuit or LCDProc.
PostPosted: Sat May 17, 2008 16:15
I haven't tried to use it with LCDProc but consider that it should work is you are using the SED1520 driver, the only problem will be that you will only be able to use 122px instead of 160px.
What is your current hardware setup?
